Re: 8 3/4 diff markings and ID help..
[Re: ECS]
#73724
06/18/08 08:12 PM
06/18/08 08:12 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
We will be offering the original type stamps by the end of the summer. They will incorporate the exact font as the ones used by the factory. Here is a sample of what was in my Challenger and the stamps I made that matched exactly what was originally there.
Is the three digit yellow number on both side or one side of the housing tube? I cleaned mine and found one but that doesn't mean the other wasn't there (if there was one on the other side).
Here's mine; '68 Charger R/T, 3.23:1 non-suregrip with 11" drums. "242"
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: ECS]
#73726
06/18/08 10:55 PM
06/18/08 10:55 PM
On OZHEMI`s photo would`nt the date code be the 2189 under the part number?
#73728
06/18/08 11:17 PM
06/18/08 11:17 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
That is the casting date of the housing unit. The actual assembly date (Gears, pinion, etc...) of the rear end would be what was designated by the white stamping.
[Re: ECS]
#73729
06/19/08 12:29 AM
06/19/08 12:29 AM
Posts: 27,484 So Cal
autoxcuda
So Cal
[Re: 70runner]
#73731
06/19/08 10:05 PM
06/19/08 10:05 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Can you guys indicate a font which is a good approximation of the 3 digit part number on the axle tube?
I found a couple that were close but not an exact match. I had to take the fonts into an "illustrator" program and convert them into "characters" in order to manipulate and change their appearance. That allowed me to match the exact font and replace what I found on my axle setup.
[Re: ECS]
#73732
06/19/08 10:38 PM
06/19/08 10:38 PM
11-10 I understand the X I`m not sure ![](/ubbthreads/images/graemlins/confused.gif) the date on the gears is what? When are you thinking you may have your stamps ready for resale?
