340 timing ?s #736923
06/29/10 07:21 PM
06/29/10 07:21 PM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
this is my first small block that i've messed with what kind of advance do they like. im running a comp 274h & 10to1 compression cam is broke in just looking for a place to start thanks ozz
Re: 340 timing ?s [Re: ozz383] #736924
06/29/10 07:39 PM
06/29/10 07:39 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
This should be in the ballpark:
18 to 24 initial, all in around 22-2600rpms, 34 total timing.
Re: 340 timing ?s [Re: ozz383] #736925
06/29/10 07:40 PM
06/29/10 07:40 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
18-22 initial
32-36 total depending on heads/fuel.
Re: 340 timing ?s [Re: YO7_A66] #736926
06/29/10 07:42 PM
06/29/10 07:42 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Depending on what the engine likes, I typically end up around 38*-39*....Low compression 340's like timing. Current 360 is at 39*. Initial to me is useless, whereas total can kill the whole engine. I never set initial, it lands where it lands. But I also run the light weight springs for a faster advance.
Re: 340 timing ?s [Re: ozz383] #736927
06/30/10 12:13 AM
06/30/10 12:13 AM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
thanks all just put the pertronix kit in and trying to get the vacuum advance moved to where the hose doesent get pinched up against the manifold hopefully running again soon ozz
