Page 2 of 3 1 2 3
Re: Green Bearings for AutoX or road racing [Re: GregCon] #736631
06/30/10 12:15 AM
06/30/10 12:15 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It sounds like you're just wanting to hear what you want to hear.
ding ding ding ... WINNER
Re: Green Bearings for AutoX or road racing [Re: JohnRR] #736632
06/30/10 12:34 AM
06/30/10 12:34 AM
Washington State
70chall440 Offline OP
Washington State
Not at all, however the oppisite seems to be the case. The guys who have run green bears seem to have nothing but good things to say about them, whereas everyone else either says "no way" or some emotionally (read not based on experience)based response. If there is someone on here who can say that they have experience with green bearings that didnt work out related to road racing or autox I am happy to hear from them. My point was/is to get feedback based on actual use. If someone were to say "I tried them on my autox and they didnt last, broke, etc" I would appreciate that information. Despite what is insinuated here, I am not predisposed to either. I will say am a bit surprised by the emotional responses.
As far as the bike technology issue goes, agian apples and oranges (I build bikes as well). The steering head on a motorcyle does not see consistant rotational forces as an axle does, rather it recieves fore and aft stress with about a 7 degree variance during riding.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: Green Bearings for AutoX or road racing [Re: DAYCLONA] #736633
06/30/10 12:35 AM
06/30/10 12:35 AM
Washington State
Washington State
The great pissin/moaning debate of Green vs Taper, on "paper" the taper is by all accounts a superior design, but so is bulletproof glass, do I need that on my car also?....I've been installing the Green bearings for well over a decade on my cars, as well as customers cars, not one failure, showcars to roadracers, drag racers to street bashers, hard miles, track time, long distance, constant abuse street or track,....I've encountered quite a few failures with tapered bearings, including 2 axle losses,(shaft leaving the housing) often due to excessive HP and roadraceing, hence the prefered change to Green bearings, I was skeptical at first also using "Green" bearings in something other than a Drag only car, but seeing that I've had zero failures with Green bearings in a multitude of my personal and/or customers cars, vs multiple failures with tapered bearings, I'm more inclined to endorse the use of Green bearings for street and/or track,(drag or roadcourse) of course proper installation and premimum parts are a mandatory criteria for maximum performance and reliability.......See Dr Diff on the Moparts board for your required application
Mike
Outstanding information. thanks.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736634
06/30/10 01:47 AM
06/30/10 01:47 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
There was a story in Mopar Muscle awhile back where they wanted to build a low buck Dana 60. They got a truck axle as a core, and used some sort of Ford axle ends with large roller bearings. They were not tapered like our original Timkens, but they had far more contact area than a ball bearing does. I wonder why nobody else has thought of going with this setup. Maybe its because of the additional expense of modifying the housing?
Re: Green Bearings for AutoX or road racing [Re: BradH] #736635
06/30/10 08:36 AM
06/30/10 08:36 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the "known fact" issue is exactly what started this thread. Everyone says it but no one has offered any real evidence other than saying that it is a "known fact".
All the major motorcycle manufacturers switched from using ball bearings in the steering head (the part of the the frame where the front suspension is mounted) to tapered roller bearings because the ball bearings would consistently develop a "notch" in the normal range of steering motion, typically right in the center where most loads occured.
Ball bearings are bicycle-grade technology. There's no way I'd run 'em in any axle application where they'd be expected to deal w/ significant side loads.
completely different application-- a steering head on a motorcycle only sees a range of motion of +/- 30 degrees max, and at high load, usually much less than that. it also sees a constant side load on the bearing (gravity).
yes, the tapered roller is a superior design, as it handles high thrust loads. but look at ford 9" and GM 12/14 bolt rears. they all use a flat roller bearing, IIRC, which doesn't carry thrust loads any better than a ball bearing....
I have been using green bearings in a hot street app for 9 years now, driving probably not _quite_ as extreme as scratchin's, but not far removed. my wilwood rear discs require them. my first set lasted only about 2k miles, but that was because I was told I didn't need to remove the thrust block/buttons in my diff. well, you don't if the axle is in the same position, but the way the wilwood kit was set up, it moved the axles inboard the thickness of the brake backing plate, which side loaded the bearings on the thrust block. when I replaced them, I put a spacer behind the brakes to move the axles out the 1/8" thickness of the old backing plate. almost 30k miles later, no issues.
2017 Grand Cherokee Overland
Re: Green Bearings for AutoX or road racing [Re: patrick] #736636
06/30/10 08:51 AM
06/30/10 08:51 AM
JohnRR Offline
JohnRR  Offline
This is an apples and oranges comparision because a FLAT ROLLER carries ZERO LOAD , the thrust load is carried by the end of the axle by a C clip and we all know what happens when the C clip lets go.
My problem with greens is I know a little too much about bearing design after taking a 3 day course given by SKF. Instead of taking a CHANCE because some people have had good luck running a bearing that is not designed to be loaded in the manner some are loading them .
All bearings will eventually fail without proper maintenance, at least the tapered roller CAN be maintained.
How many of your green autocross users are greasing your SEALED bearings ???
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736637
06/30/10 10:53 AM
06/30/10 10:53 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Id like to hear from someone who has actually tried using green (non-adjustable) rear bearings for autoX or road racing. I have read tons on the internet and still have not found any definitive on this issue. The urban legend says "no" but all I find is therorethical informaiton, no actual "been there done that" type info. I have seen quite alot of poeple who say they use them w/o issue but no one says in a road race or autox environment. If someone has real data I would like to hear it.
I'd say that the Green bearings bad reputation has everything to do with the questionable quality of the bearing and nothing to do with the fact that it is a sealed ball bearing. Sealed ball bearings have been used in millions of Fords throughout the years. Most of the later big 3.15" axle bearings in 9" rear were sealed ball bearings (used in F150, Bronco, big Lincolns, wagons) and all the small axle bearings used in Mustangs including Shelbys, Cougars, Falcons Fairlanes etc with 8" and 9" rears were sealed ball bearings. None of these bearings were known for failure and I'm sure the Shelbys were flogged pretty hard on the roadcourse and autocross back in the day. 7.25 mopar also has a sealed ball bearings and they last forever.
Re: Green Bearings for AutoX or road racing [Re: 446acuda] #736638
06/30/10 11:54 AM
06/30/10 11:54 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
No one said ball wheel bearings are STRONGER than tapered wheel bearings.
In reality, ball wheel bearings are adequate for most applications, and they are MUCH MORE COMMON than tapered rear wheel bearings. Ford, GM, Toyota and even Chrysler installed MILLIONS of them in production vehicles over the years.
Re: Green Bearings for AutoX or road racing [Re: JohnRR] #736639
06/30/10 12:00 PM
06/30/10 12:00 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
umm, err, how many ford 9" rear are C-clip axles?
Re: Green Bearings for AutoX or road racing [Re: patrick] #736640
06/30/10 01:23 PM
06/30/10 01:23 PM
JohnRR Offline
JohnRR  Offline
I should have said a flat roller carries no side load. No c clips in the 9", yes , but do they use a flat roller or a ball bearing ?
Forget I said anything , someone wants to run greenies in auto cross , knock yourself out. I've got enough NOS tapered sets, with retainers, to last me 2 lifetimes in 4 cars .
Re: Green Bearings for AutoX or road racing [Re: DoctorDiff] #736641
06/30/10 11:12 PM
06/30/10 11:12 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Where did I say that ball wheel bearings were stronger? I'd prefer tapered bearings but ball bearings get the job done in most applications. My main point was that the green has a QUALITY issue, not a design issue. In other words, if mopar made the 8-3/4 and Dana with an O.E. quality ball bearing, then we wouldn't even be discussing bearing failures here.
Re: Green Bearings for AutoX or road racing [Re: 446acuda] #736642
07/01/10 01:22 AM
07/01/10 01:22 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I wasn't replying to you. I was adding to the thread.
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736643
07/01/10 06:18 AM
07/01/10 06:18 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
So I guess the summary of the answers you're looking for is this:
Ball or flat roller bearings are perfectly acceptable for std passenger car/truck use, but have a predictably shorter life span than a tapered bearing, especially is subjected to excessive abuse. They will work in hi load situations, but probably for not as long as a tapered bearing
Hopefully this summary will ensure no-one else spits the pacifier out of the cot.
Re: Green Bearings for AutoX or road racing [Re: DoctorDiff] #736644
07/01/10 06:20 AM
07/01/10 06:20 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
A major member of this board has had two sets of green bearings fail on his ragtop and has gone back to the factory bearings on his steet car.
I'll point this thread out and see if he chimes in.
Been doing Mopars since '84, as a line tech and gear head, never seen a factory (8.75 taper) bearing fail.
I'll politely point out that most stuff for our cars is made overseas and has poor quality control, I suspect that has more to do with the failure rate than anything.
Most people would rather take the easy route then the best route, green bearings fall into that category.
Gary
Re: Green Bearings for AutoX or road racing [Re: gdonovan] #736645
07/01/10 07:09 AM
07/01/10 07:09 AM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
"Ball or flat roller bearings are perfectly acceptable for std passenger car/truck use"
Sadly, no. Replace 'perfectly' with 'marginally' and you'll get a gold star on your forehead.
Re: Green Bearings for AutoX or road racing [Re: GregCon] #736646
07/01/10 07:50 AM
07/01/10 07:50 AM
Moparmal Offline
Moparmal  Offline
I'll let you argue that with Henry, Walter P and the General...
Re: Green Bearings for AutoX or road racing [Re: Moparmal] #736647
07/01/10 07:58 AM
07/01/10 07:58 AM
scratchnfotraction Offline
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736648
07/01/10 08:16 AM
07/01/10 08:16 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
to the OP : my cuda is currently using its 4th set of green bearings in 3 years. Green bearings were installed along with a Wilwood rear disc brake kit. With the current configuration (no axle seals in the housing, and the inner bearing cage seal ripped out before installation, so the bearing can be lubricated by the diff fluid ), it seems the 4th set might outlive its three predecessors. Set #2 was really driven for one day (which included 20 spirited minutes on a racetrack).
I can't switch back to OE bearings easily (need custom length axles or a custom-length centre pivot in the Truetrac diff like I did in my Challenger), or else I would do it in a pinch.
Re: Green Bearings for AutoX or road racing [Re: fbernard] #736649
07/01/10 10:01 AM
07/01/10 10:01 AM
fbernard..
are you running the thrust block in the diff with the disc brake set up?
might be why they do not hold up,it places a lot of side load on the bearing
may have to add a spacer like patrick did on his to take up the diff of the missing backing late or remove the thrust block alltogether like I did
with the one sealed side open to diff fluid does it seep/wick thru the other side of the bearing with out the housing seals?
Re: Green Bearings for AutoX or road racing [Re: JohnRR] #736650
07/01/10 10:09 AM
07/01/10 10:09 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Page 2 of 3 1 2 3
