I have a set of MSD 8.5 Super conductor wires that I have been kicking around for a long time. I have never used them, bought them and sat them on the shelf.
Now that I am converting from the stock mopar distributor to and MSD HEI (same with the coil) I am toying with the idea of changing the boots from the straight to
MSDs High Temp. 90 degree boots and the
HEI terminals at the distributor and coil.
So my question is, How do you do it? Would you cut the old boots off with a razor blade?
![](/ubbthreads/images/graemlins/sawzall-smiley.gif)
Pry the old terminals off and treat it as a new wire. Crimp on the new terminal and then press on the new boot?
![](/ubbthreads/images/graemlins/shruggy.gif)
