Re: Go Green going good 6.94 @ 209.44
[Re: go green]
#735386
06/28/10 04:46 PM
06/28/10 04:46 PM
Posts: 8,165 Left Coast
BobR
Left Coast
It shows 100 at idle ( it was a really hot day ), mid run 145 and end of run 190 .
This is all pre methanol temperature numbers.My injectors are all down runner from the manifold air sensor.
The sensor is at the back of the manifold.
That is exactly what I wanted to know. Thanks, Dean. Have you tried M5?
[Re: jamesc]
#735387
06/28/10 04:49 PM
06/28/10 04:49 PM
BobR
Left Coast
This run was at 22 PSI
you run a standard adjustable wastegate or do you use any type of controller? i would think if it's allowed a wastegate controller would be standard on a car like that...nice workmanship and numbers
I'm sure he has a controller. It's the only way to get these "small tire" cars off of the starting line cleanly.
[Re: go green]
#735394
06/28/10 07:56 PM
06/28/10 07:56 PM
BobR
Left Coast
24 PTE #160 injectors and a AMS 1000 with turbosmart 60mm waste-gates
M5?????
[Re: go green]
#735395
06/28/10 08:03 PM
06/28/10 08:03 PM
Posts: 740 WA
JD Dart
WA
[Re: Chris'sBarracuda]
#735399
06/29/10 10:20 AM
06/29/10 10:20 AM
Posts: 778 Sherwood park, Alberta.
go green
So what did you do to stop the head gasket blowing and torching the blocks?
Getting waaaay down there.. But I know you want more.. ![](/ubbthreads/images/graemlins/thumbs.gif)
Chris..
When I first put the engine together I used a Cometic gasket based of a standard BBD . This gasket has relief cuts encroaching into the firing ring seal to accommodate the in-line valve placement.The dowel pins on the heads are close to the bore when you get to 4.5" bores and consequently that zone has the greatest distance between head bolts. I think a few small factors might of added up to a week zone for the cylinder preasure to escape and damage the block and cylinder head. ( no my dowel pins were not holding my head up )
![](http://i307.photobucket.com/albums/nn289/googreen/heads005.jpg)
![](http://i307.photobucket.com/albums/nn289/googreen/promodcuda006.jpg)
You can see in the picture that even the dowel hole is in the sealing ring area. The physical properties of the gasket made failure only a matter of time ( actually a matter of preasure but time sounds more dramatic )
So its on to plan B
- more clamping force on the affected area - remove dowels from beside the bore zone. - physically hold the gasket in place with o-ring
![](http://i307.photobucket.com/albums/nn289/googreen/001-1.jpg)
