1968 power steer box seal replacement #735296
06/27/10 11:28 PM
06/27/10 11:28 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Is there any thing to look out for when changing the column input shaft seal?
Is just disconnect coupler and pop out seal?Any tricks?
thanks
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 1968 power steer box seal replacement [Re: tex013] #735297
06/28/10 01:08 PM
06/28/10 01:08 PM
Ft. Wayne In.
Gmg0045 Offline
Gmg0045  Offline
Ft. Wayne In.
Bump! I have the same need for info!
Re: 1968 power steer box seal replacement [Re: Gmg0045] #735298
06/28/10 05:52 PM
06/28/10 05:52 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
what,nobody ever change this seal ?
Factory manual says R&R steering box to replace.i guess removal/moving column will give access?
i do have hooker headers on a 440.
Tex
New best MPH 130.32
