Re: 727 question for trans gurus
[Re: bigD]
#735210
06/28/10 04:27 PM
06/28/10 04:27 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Have you checked the end play on the crankshaft?
[Re: John_Kunkel]
#735211
06/28/10 10:26 PM
06/28/10 10:26 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
John,I did think of that,but the engine only has a few hundred miles on it.Seems strange it would stop when the tranny has fluid in it, but then again I've seen cranks(chevys) move forward and aft by depressing a stiff clutch with a bad thrust. Could you enlighten me a little more as to what is going on with the 727 that would make the sound(s) I described( ie converter moving in and out of the pump housing ect.) Thanks, D. ![](/ubbthreads/images/graemlins/beer.gif)
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: gasman]
#735213
06/29/10 10:52 AM
06/29/10 10:52 AM
bigD
Hatfield,Pa.
Loose bolts crossed my mind also,I'll check them first and see what happens,D. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: John_Kunkel]
#735215
06/29/10 10:39 PM
06/29/10 10:39 PM
bigD
Hatfield,Pa.
John,thanks for the reply ![](/ubbthreads/images/graemlins/thumbs.gif) .Your wag is exactly what I was thinking,just needed to know if I was going in the right direction,D. ![](/ubbthreads/images/graemlins/beer.gif)
