Driveshaft failure diagnosis
#734252
06/26/10 08:01 PM
06/26/10 08:01 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Driveshaft failure diagnosis
[Re: WILD BILL]
#734254
06/26/10 08:08 PM
06/26/10 08:08 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my first guess would be the little bity bolts for the straps
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#734255
06/26/10 08:17 PM
06/26/10 08:17 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Looks to me like the the C clip wasn't properly seated on the one cap and most likly came off allowing the cap to slide out of the shaft. Once that happened it samcked and tore off the bolts.
Look closly at the cap that is still in the shaft and it looks like there is to much space between the C lip grove and the inside of the yoke for the other cap to be seated properly.
[Re: WILD BILL]
#734256
06/26/10 08:18 PM
06/26/10 08:18 PM
WILD BILL
BROOK PARK, OH
And yes, I know that from experiences
[Re: DoctorDiff]
#734258
06/26/10 09:28 PM
06/26/10 09:28 PM
fasteddie
Bristol, Va
What suspension are you running? What is your pinion angle?
CalTracs with the split mono leafs & 9000 shocks all from Calvert. 3 degrees down from yoke to shaft.
I just took the replacement shaft out for an inspection and everything looks ok after 16 runs. Replacement joints are the Brute Force joints.
[Re: fasteddie]
#734262
06/26/10 11:44 PM
06/26/10 11:44 PM
Might wanna check the sprag in the transmission while you're at it since this happened...
[Re: WILD BILL]
#734267
06/28/10 02:46 AM
06/28/10 02:46 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Looks like the C-clip was missing or installed wrong on the driveshaft. Once the cap came out it tore the straps off the yoke. Did you feel a driveshaft vibration right before it let loose?
[Re: 451Mopar]
#734268
06/28/10 06:47 AM
06/28/10 06:47 AM
Posts: 2,926 A shed in England
Tig
A shed in England
I just seen this exact same thing the weekend before last. No previous issues, the guy upgraded to a new driveshaft and bigger joints etc. Is it a 1350 spicer joint? Maybe theres a bad batch or some fakes going round The guy was pitted next to me, he didn't spit the drive shaft out, just developed a bad vibration. We helped him change it, looked like the outer needle race had cracked. This was one in the prop at the rear BTW, not the yolk, so it probably wasn't overtightened.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: fasteddie]
#734270
06/28/10 11:44 AM
06/28/10 11:44 AM
Posts: 43,230 Bend,OR USA
Cab_Burge
I would replace that yoke with a new billet steel yoke, there cheaper than new spicer forged yokes and stronger. Make sure the new U joint presses or pops into place, a tight fit that will not fall out if you hold the yoke upside down and shake it The straps are on there to keep the U joint from being pryed out frontwards when the driveshaft turns, there not there to keep the U joints from flying out, that is the internal keepers job Let us know what you do and how that works
