which cam #734095
06/26/10 05:22 PM
06/26/10 05:22 PM
virginia
tigger1 Offline OP
tigger1  Offline OP
virginia
Building my son his first toy. 72 datsun truck, box frame, Dana, ladder bars,440,727. Motor is 76 low compression all stock. I have mechanical rockers and building on a budget. What mechanical cam to use? I have stock duel plane or TM 7. 1 7/8 headers, 750 edelbrock Carb, and 2400 stall. May buy new converter at higher stall
Twin turbo 440 72 barracuda
Re: which cam [Re: tigger1] #734096
06/26/10 08:06 PM
06/26/10 08:06 PM
The Great White North
RAMM Offline
RAMM  Offline
Use the TM-7 it's pretty good. Don't bother with a cam swap until you get the block decked/heads worked a 'lil/compression ratio way upped--etc...
But if you must don't go anywhere near the .484 purple--even that is way too much. Go smaller or better yet-leave it alone. I'm sure a Datsun truck with a 40 will be plenty for a while. This is my best advice.J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: which cam [Re: tigger1] #734097
06/26/10 10:33 PM
06/26/10 10:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
Comp Cams high energy 260H or maybe the 268H with the TM7 intake install it per the instructions on the intake lobe timing
