So I have a 750 double pumper with a pro form main body worked over by quick fuel. Has 4 courner idle, adjustable air bleeds, and all the goodies. I have a pretty healthy little 360, nicely ported J heads, a really nice comp hydro roller cam, and a set of 10 to 1 kb pistons in it. In second gear at about 3000 rpm, when I go to snap the throttle, or even just slightly roll into it slowly it has a dead spot in it, and Its running a bit rich. I have 72 jets in the front and 74s in the secondaries. Where is the dead spot coming from? Do I have the wrong accelorator cam in the thing, or the wrong power valve? My cam is speced at @50 236 INT, and 242 EXH, and the lift is .570 INT, ans .550 EXH with a lobe separation of 112.0. It idles fine, never gets over 190, but isnt very responsive, kinda sluggish from an idle. I have the timing set at 34 overall, and have a MSD ignition with a mopar performance 6AL. Just want to get a base line on the carb setting, It runs like hell above 2000, and pulls great through 6000, I just want it leaned out a bit, and the dead spot to go home.
Oh it idles at 800, and its lumpy as hell.\
Kasey
