header collectors #733598
06/25/10 09:30 PM
06/25/10 09:30 PM
W.Va
fowl play Offline OP
W.Va
went from 1 7/8 headers 3 inch collectors to 1 7/8 with 3 1/2 inch collectors on 414 inch smallblock in a dart. ran the best with the 3 inch with no extentions. what is the thought, will i need extentions on the 3 1/2 inch collectors. what is the thoughts on this and the length? thanks
Re: header collectors [Re: fowl play] #733599
06/25/10 09:34 PM
06/25/10 09:34 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Every combination is different and the only way to know is to run it. My guess is that you may need the 3 1/2" collector to be a little longer but maybe not.
Re: header collectors [Re: BobR] #733600
06/25/10 10:15 PM
06/25/10 10:15 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Put on extensions , stripe them with a crayon , run them once and cut them within an inch of where the mark starts to burn.
