a833 4-speed resto---exterior color #730621
06/21/10 07:16 PM
06/21/10 07:16 PM
washington
67383scuda Offline OP
washington
--hi moparts.
im restoring my 1970 e body 4 spd to its former glory. working on the outer case..its metal
my q is now that its cleaned-- what color should it be painted..tailshaft etc...or is just whatever i like (i.e black or something.)) or bare metal..
thanks moparts!
Re: a833 4-speed resto---exterior color [Re: 67383scuda] #730622
06/21/10 07:25 PM
06/21/10 07:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Originally they were natural/bare.
Re: a833 4-speed resto---exterior color [Re: topside] #730623
06/21/10 08:44 PM
06/21/10 08:44 PM
washington
washington
-thanks. --
-i thought there was a paint that looked like metal and helped prevent any rusting. ..
Re: a833 4-speed resto---exterior color [Re: 67383scuda] #730624
06/21/10 09:44 PM
06/21/10 09:44 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I paint mine with cast grey....You can also shoot over the paint with a light coat of cosmoline spray to give the paint a more natural look.
CHECK OUT MY NEW WEB SITE !
Re: a833 4-speed resto---exterior color [Re: 67383scuda] #730625
06/21/10 09:48 PM
06/21/10 09:48 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Paint is paint, some match the natural color of bare cast iron better than others, all help prevent rust because they cover the bare metal. Bottom line? NONE of them are "Correct".
If you want to leave it bare cast iron and keep rust away there are several metal treatments that will help but none will last forever without periodic maintenance.
Re: a833 4-speed resto---exterior color [Re: anlauto] #730626
06/21/10 09:55 PM
06/21/10 09:55 PM
anlauto Offline
anlauto  Offline
I agree 100% with Scott ANY paint is not correct.....
...but it's pretty
Re: a833 4-speed resto---exterior color [Re: anlauto] #730627
06/21/10 10:28 PM
06/21/10 10:28 PM
washington
washington
--great input..
ok so now what works best for cleaning that metal to the level you see in those pics? media blast or sand blast? dipping it? not flaky rust just mild surface..
thanks moparts
Re: a833 4-speed resto---exterior color [Re: 67383scuda] #730628
06/21/10 10:43 PM
06/21/10 10:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Start with detergant/degreaser and get more aggresive as required, sandblasting would be LAST on my list. Try to keep the original surfaces as natural as possible without pitting them with blasting (especially any machined surfaces) commonly available liquid products like Ospho and Evaporust rust remover disolves rust without eating the metal. When you start removing scale and grease you'll likely find traces of the original paint markings and stamps similar to shat is on Alans restored trans, make stencil patterns of them and take ALLOT of pics and measurements before destroying them as no 2 are exactly the same.
Re: a833 4-speed resto---exterior color [Re: ScottSmith_Harms] #730629
06/21/10 11:09 PM
06/21/10 11:09 PM
washington
washington
--thanks--
Re: a833 4-speed resto---exterior color [Re: 67383scuda] #730630
06/22/10 07:34 AM
06/22/10 07:34 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
This one I lightly glass bead blasted, then Krylon Satin clear for a topcoat to prevent rusting.
Made my own 603 stencil by tracing the original numbers and cutting it out of a thin sheet of rubber.
