E Body rack and pinion #728725
06/20/10 06:20 AM
06/20/10 06:20 AM
Chambersburg ,PA 17201
mopar4u Offline OP
mopar4u  Offline OP
1.)Who has installed one of the rack and pinion kits on an E-body? 2.) What's the best kit? 3.) What Problems, if any, to install?
Re: E Body rack and pinion [Re: mopar4u] #728726
06/20/10 07:12 AM
06/20/10 07:12 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
If you do a search, you may find that the best way to get a rack is to use a kit that replaced the Kframe and all front suspension components, like AlterKtion or XV.
Re: E Body rack and pinion [Re: Pool Fixer] #728727
06/20/10 09:23 AM
06/20/10 09:23 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
Go to capauto.com.
Re: E Body rack and pinion [Re: mopar4u] #728728
06/20/10 11:52 AM
06/20/10 11:52 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Friend of mine recently made the mistake of putting a power rack&pinion system on his '70 Roadrunner. Not sure of the brand and such. Someone told him it was better than the stock steering system. Now he has had nothing but problems with linkage angles and toe-in settings changing during accelerating, making the car dangerous to drive.
He had the entire R&P-assembly moved about 3" under the car to improve the linkage-angles.
Now he's not really up to snuff when it comes to this technical stuff and farms out most of the work to others, but I wonder how and IF this system was designed to work on a stock K-member car.
Re: E Body rack and pinion [Re: BigBlockMopar] #728729
06/20/10 12:20 PM
06/20/10 12:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Look at RMS.Bill makes a nice setup.Typically you have tons of problems just trying to stuff a rack under one.You usually get a lot of bump steer.Rocky
Chrysler Firepower
Re: E Body rack and pinion [Re: Pool Fixer] #728730
06/20/10 12:27 PM
06/20/10 12:27 PM
mopar4u Offline OP
mopar4u  Offline OP
That's what I'm thinking. replace everything as a package.
Re: E Body rack and pinion [Re: mopar4u] #728731
06/21/10 07:27 AM
06/21/10 07:27 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
the RMS AlterKtion has a good rack (which is installed in front of the engine, by the way, not taking the place of the OEM steering link).
I have the power version, and it's not too assisted (unlike OE steering boxes), which feels much safer. There's a manual version available.
But replacing the whole K-member and suspension just to install R&P seems a little extreme.
What's the rationale for wanting R&P in the first place?
