Page 1 of 3 1 2 3
Why can't I get the tires to light up? #728498
06/19/10 09:26 PM
06/19/10 09:26 PM
US
Jay68RR Offline OP
Jay68RR  Offline OP
US
68 RR, 383, auto, 160k miles, no rebuild, recently had sure grip, 3.73, and XE268 cam put in, MSD, TTI headers and exhaust. No head work, no intake work.
Auto on the column and when I do it manually, it shifts very strong from 1st to 2nd (to the point where the rear end gets a but swirly), but from a standstill if I floor it it won't break the tires loose. Why the hell not? Any thoughts?
'68 Road Runner, 383 Torqueflight, 3.73 Sure Grip, TTI headers, MSD
Re: Why can't I get the tires to light up? [Re: Jay68RR] #728499
06/19/10 09:37 PM
06/19/10 09:37 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
My friend has a 68 383 runner and has to powerbrake in order to spin the tires. My 440 however, no problem.
Re: Why can't I get the tires to light up? [Re: repad] #728500
06/19/10 09:51 PM
06/19/10 09:51 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
advance the timing
Re: Why can't I get the tires to light up? [Re: mopargem] #728501
06/19/10 09:59 PM
06/19/10 09:59 PM
US
Jay68RR Offline OP
Jay68RR  Offline OP
US
So other 383's are like that- interesting. That worries me for when I get to the drag strip at some point. If I can't even light the tires up, it seems I'll have a horrible 1/4 mile time.
Advance the timing huh? I'll look into it. Thanks.
Re: Why can't I get the tires to light up? [Re: Jay68RR] #728502
06/19/10 10:01 PM
06/19/10 10:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Spinning ain't winning. What kind of times are you ecpecting to run?
Re: Why can't I get the tires to light up? [Re: Jay68RR] #728503
06/19/10 10:04 PM
06/19/10 10:04 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
160K with no engine and head work? i would guess after the bigger cam your very low on cranking psi.
Re: Why can't I get the tires to light up? [Re: ademon] #728504
06/19/10 10:19 PM
06/19/10 10:19 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Not spinning is not much to go on here.
It may be an ignition timing or carb set up away from making you very happy.
I do remember my 70 Road Runner not being able to do much flat stab tire spinning but in stock form but with a few minor bolt ons like headers and a Holley and 3.54's. It would cut a 1.9 60'
Re: Why can't I get the tires to light up? [Re: Magnum] #728505
06/19/10 10:47 PM
06/19/10 10:47 PM
NJ
440challenger Offline
NJ
I have a 383 roadrunner also. 4.10s auto.
906 heads,performer rpm,purple shaft,msd,header etc. Im pretty dissapointed also. i have 18.5 inital and 36 total timing. it will break the tire loose but barely. I think the 383's are just dogs unless you got some compression in it
Re: Why can't I get the tires to light up? [Re: 440challenger] #728506
06/19/10 10:51 PM
06/19/10 10:51 PM
Make sure you're at 34-36* total timing with the vacuum advance hose off.
Make sure the mechanical advance (weights) aren't sticking and keeping the timing from advancing.
Install Mr. Gasket #925B lightweight springs in the distributor to get the advance to come in quicker.
It's never going to be a monster but the little tuning tweaks will help...
Re: Why can't I get the tires to light up? [Re: 440challenger] #728507
06/19/10 10:54 PM
06/19/10 10:54 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Got to have at least 10-1 and it will still run on pump gas.
8.8-1 motor is gonna run like that. My
Re: Why can't I get the tires to light up? [Re: 440challenger] #728508
06/19/10 10:55 PM
06/19/10 10:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
prober degree on the cam will make it like night and day!
Re: Why can't I get the tires to light up? [Re: 440challenger] #728509
06/19/10 10:59 PM
06/19/10 10:59 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
What STALL is the converter? If it is an 12 inch unit from a New Yorker or another big car, the cam needs much more stall. The stock stall speed for a 383 Road Runner was supposed to be around 2350-2500. Those Big C body car low stall converters were about 1600-1800. Going to a cam that much larger than stock means a matched converter is needed.
The fat cam starts making real power from 3000 rpms on. If the converter stalls too low, the low rpm performance will be soggy, much like releasing the clutch in a 4 speed car at 1600 rpms and stabbing the throttle.
Re: Why can't I get the tires to light up? [Re: 440challenger] #728510
06/19/10 11:00 PM
06/19/10 11:00 PM
US
Jay68RR Offline OP
Jay68RR  Offline OP
US
That sucks. What about all the talk of these cars having lots of torque? I understand that spinnin aint winnin, but come on. I'd expect with such high mileage and no rebuild to run 15's or 16's. After I do get a rebuild, the heads and intake, etc done, to get 13's.
I'm not sure what crank psi is. And if compression has to get up, I assume that's when the headwork should take care of that with the proper setup.
Re: Why can't I get the tires to light up? [Re: Jay68RR] #728511
06/19/10 11:07 PM
06/19/10 11:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
15s are realistic. You'd have to do a serious build to get into the 13s. In order to get much compression you will need to change pistons because the stock 2bbl pistons are dished. Right now you are somewhere between 7.5 and 8.5 to one.
Re: Why can't I get the tires to light up? [Re: Kern Dog] #728512
06/19/10 11:11 PM
06/19/10 11:11 PM
US
Jay68RR Offline OP
Jay68RR  Offline OP
US
I have to assume the stall is stock. Got the car 5 years ago so who knows. If it is stock and it is 2250 to 2500, then is the XE268 too big until I get a bigger stall???
So it looks pretty agreed upon that the timing has to be dialed in correctly. Thanks everyone.
Re: Why can't I get the tires to light up? [Re: Dodgem] #728513
06/19/10 11:17 PM
06/19/10 11:17 PM
Point well made!
Did you degree in the cam when it was installed?!?
My last BB cam install was 8* retarded with "the dots lined up"!
Would've made for sick puppy if I'd installed it that way.
Other than that, I think blow-by on the high mileage motor is going to be the biggest issue.
Re: Why can't I get the tires to light up? #728514
06/19/10 11:31 PM
06/19/10 11:31 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Don't know, but back in 84 i had a 70 Sport satty with the 383 Commando, it was all bone stock & would light the fire out of the tires , had really good torque too, I eventually installed some 4.11s out of a charger, the car was a screamer, maybe leaving it stock would be better
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Why can't I get the tires to light up? [Re: Jay68RR] #728515
06/19/10 11:35 PM
06/19/10 11:35 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
You may have several issues; timing,carb etc. Even with everything tuned properly,383s just don't have a lot of low end power. It's a small displacement, short stroke, big bore, big block. It has a shorter stroke than a 350 chevy and a bore size the same as a 454. It likes to rev. Pistons are heavy though. Don't be afraid to put some stall in it. A swap from a stock converter that flashed to about 1700 rpm to a MP converter that flashed to 2800 was a big improvement in my XE268 equipped 400 RR. Would have put more converter in it but the MP unit was cheap( about $175 at the time) and this car is my economy car
Re: Why can't I get the tires to light up? [Re: Jay68RR] #728516
06/20/10 12:06 AM
06/20/10 12:06 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Up until three years ago my Coronet with a 383 out of a '71 Newport would only spin the tires from a stop for about 5 feet, at best. Today, from a stop not power breaking, slamming the throttle to the floor from a stop, the 275/50/15's spin 40 or so feet in first and spins them slightly hitting 2nd.
1965 Coronet weighs 3,700 with me in it.
383ci, 15 degrees initial, 40 degrees total all in by 2,500 RPM's, XE262H Comp Cam, Performer RPM, 750 (3310) Holley, Tri-Y headers, stock "blended" heads w/3 angle valve job, MSD ignition, clutch fan, 2.5" exhaust with y-pipe, 727 auto, 12" torque converter that stalls around 2,200, 3.73 rear gears, 275/60/15 rear tires.
What got me there? Tune, tune, tune, tune, tune...and tune some more.
BTW, I shift at 5,700.
That's a fact Jack.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Why can't I get the tires to light up? [Re: Junky] #728517
06/20/10 12:51 AM
06/20/10 12:51 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
My old 4 door valiant 323" 4 speed beater, with streetmaster 318 single plane, 600 holley, 3.31 gears, factory HEI, and 4.30/.444" lift 340hp cam, had no problem. With 225/60/15's smokey burnouts are not the problem, but tire prices. There is something to be said for factory performance. In top form it did high 14'80's.
Keep at it. A 383 has the size for good power. All it takes is a little money. You will eventually learn the relationship between fuel and timing, and how it all works. Not rocket science for Sams' sake.
Page 1 of 3 1 2 3
