Re: Mopar Muscle 440 build
[Re: 69 GTX]
#727829
06/18/10 11:58 PM
06/18/10 11:58 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Can anyone give me a link to a 440 build where they decked the block .070 with 2266 pistons, I looked on the site and can not find it, Thanks
I don't think I have seen that post, any idea how old it may have been? Cutting the block that much is going to make it hard to use a stock intake/valley pan gasket and the intake or heads will also need to be milled to fit correctly.
[Re: 69 GTX]
#727830
06/19/10 12:08 AM
06/19/10 12:08 AM
Posts: 75,103 A Banana Republic near you.
JohnRR
you do not want to deck the block that much , by the time you pay for all decking of the block and an intake or a set of heads on the intake surface you could have just bought the right piston
[Re: 69 GTX]
#727832
06/19/10 09:37 AM
06/19/10 09:37 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks, I think I found it, it was .020 to compensate for the thicker head gasket and to duplicate stock CR
probably better of buying good pistons or just use a steel shim head gasket.
