Re: Coil fire Question-350 microseconds vs 1,500 microsecs?
[Re: T/A CARe]
#727542
06/18/10 04:09 PM
06/18/10 04:09 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I wouldn't worry about burning the spark longer into the ignition sequence. It will help burn the itty bitty stuff that's hard to ignite. Unless you have a problem it shouldn't be significant.
If you change WHEN it starts the burn you're going to have a problem. That means you're advancing or retarding the timing.
Let it burn into combustion. No problem there.
