Re: Help.. 416 stroker crankcase pressure
[Re: showoff220k]
#727066
06/17/10 08:44 PM
06/17/10 08:44 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
if you have a lot of crankcase pressure the first thing I would do is a leak down test to see if there is a problem with ring seal.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: showoff220k]
#727069
06/18/10 11:45 AM
06/18/10 11:45 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
There is a mechanical problem in the engine. I second the leak down test or at minimum a compression test to see where exactly. Sounds like rings are not/did not seat... Or as was noted, the rings butted. Tear it down an look.
[Re: showoff220k]
#727072
06/18/10 09:32 PM
06/18/10 09:32 PM
dusturbd340W5
Kissimmee Fl.
wow all 8 cylinders are you sure the deck and heads are flat I am running FelPro 1008's on my 416 with 12.5-1 with no problems and am getting ready to bump it up to 13.5-1
[Re: dusturbd340W5]
#727073
06/18/10 09:38 PM
06/18/10 09:38 PM
Posts: 7,506 Az
Crizila
Az
Ya, something else aint right there. If you are running head bolts ( verses studs )you might want to check to make sure they are not bottoming out in the block. Don't know on W2's, but it can be a problem with magnum heads / bolts and LA blocks.
Fastest 300
