Rear Shock Settings
#726926
06/17/10 06:07 PM
06/17/10 06:07 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Hi ! I`m planning on getting the car out to the track in the next couple of weeks and actually getting on it hard. (haven`t yet made a full/hard pass - mechanical issues). I`m running leaf springs , a C/E axle floater , and ladder bars. The car has a Glide w/brake and a MagForce front end . The car is powered by an alloy Hemi 874hp/750ft.pds . I have 14.5/32/15 Goodyears with D3 rubber . Where should the rear double adjustable Afco rear shocks be set and what about the front single adjustable Aldans ? Sure appreciate some feedback on this one Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Rear Shock Settings
[Re: chryco]
#726927
06/17/10 06:16 PM
06/17/10 06:16 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I would defiantly set the front on the 90/10 setting or the most fast/easiest extension setting. On the back its just hard to say, so I would set them in the middle, have someone there knowledgeable watching, and if possible record and video the launch. Dont be two quick to make changes, make a few passes for consistency, and only make one shock change at a time. Cool car you have...and good luck
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: chryco]
#726928
06/17/10 06:23 PM
06/17/10 06:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wouldnt set the fronts on the light setting... I would start on the stiffest setting in the fronts with your light weight hemi and a lightened front end... I think its going to come up easy enough... rears... try about 3/4 stiff(extension)... but that will depend on the ladder bar setting
[Re: MR_P_BODY]
#726929
06/17/10 07:20 PM
06/17/10 07:20 PM
Posts: 656 Kokomo, IN
540dust
Kokomo, IN
At least put the fronts somewhere in the middle for the first passes until you see what it does, wouldn't be good the first pass to rip off the back bumper and smash and oil pan. Start conservative then loosen up if it wants it.
[Re: 540dust]
#726930
06/17/10 09:09 PM
06/17/10 09:09 PM
chryco
Winnipeg ,Mb. CA.
Yeah middle to soft on the rear , and I`m not sure it really matters on the front so much? I wonder how much difference using the t-brake would have on how I set up the shocks? The same ,or just that things will react faster with the brake? Oh yeah , then there`s the air pressure issue for the slicks....... Chryco
[Re: chryco]
#726931
06/18/10 12:29 AM
06/18/10 12:29 AM
Posts: 43,243 Bend,OR USA
Cab_Burge
I recently switch my rear coil over shocks from Strange Engr. single adjustable to double adjustable, I ask on here for suggestions and got some. I started with mine set in the middle on both settings, the car spun. I change both settings to dead soft and the car hook good, just like it did with the single adjustables. I then treid two clicks stiff on the compression and saw no measureable changes, ET, 60 ft. times or reaction times. I ended up trying two clicks on the extension and didn't see a measurable change with that setting either That was it for that weekend, I am going to Woodburn this weekend to run the car with this motor and shocks at a 1/4 mile track at a low (180 ft. instead of 2500 ft at our home track) altitude I am planning on testting the shocks some more, if time allows I would take MRPbody advise and set the fronts on stiff and set the rears on dead soft on both extension and compression BTW, how old are your tires? If less than six months and no runs do a normal burnout, not a John Force style funny car one, if older than six months and if they have been run you may need to do a J.F burn out the first time, maybe not Good luck, let us know your results
[Re: Monte_Smith]
#726933
06/18/10 06:47 AM
06/18/10 06:47 AM
chryco
Winnipeg ,Mb. CA.
My tires are new and have only one burnout on them. I used to run about 7 - 8 # in them with the 340 set up and no problems. But this is going to be a whole new ball game with the Hemi/Glide set up. The Glide has a 1.76 1st gear too btw. Any tire pressure rec`s? Thanks for the input so far too ! Chryco
[Re: chryco]
#726935
06/18/10 06:44 PM
06/18/10 06:44 PM
MR_P_BODY
Do you feel its about the same weight as before and what trans did you use before... if it was a 3 speed as in a 727 or 904 then going to the glide I would try them where you ran them before and video your launch... the glide will hit them easier but watch your side walls.... I run 7# in my 14x31 with a 2400# car with 52% on the rear Try them at 8# and then adjust, 7# may be on the low side
[Re: chryco]
#726937
06/19/10 08:05 AM
06/19/10 08:05 AM
MR_P_BODY
In your vid there, was there something wrong with the right front wheel... looks way out...... good luck with the car... looks great
[Re: MR_P_BODY]
#726938
06/19/10 09:07 AM
06/19/10 09:07 AM
Posts: 118 Ms.
Dartwizer
Ms.
I see it too.Had to be pulling really hard..
[Re: MR_P_BODY]
#726939
06/19/10 09:15 AM
06/19/10 09:15 AM
Posts: 705 Michigan
Hemiroid
Something looks way wrong with the right wheel/tire. Looks like it was toed way out
[Re: Dartwizer]
#726940
06/19/10 09:17 AM
06/19/10 09:17 AM
chryco
Winnipeg ,Mb. CA.
Yeah , that problem was dealt with at the end of last season . Basically the steering arm bent on that spindle. They are made by Afco and work with the aftermarket front end I`m using. The front end manufacturer fixed both units so this wouldn`t occur again . This was apparently an early design (f/e)and has been redesigned since.I`ve re installed it found no binding and the alignment is also good. We`ll see. Chryco
[Re: chryco]
#726942
06/19/10 09:22 AM
06/19/10 09:22 AM
MR_P_BODY
Ok... glad you got that taken care of
[Re: chryco]
#726944
06/19/10 09:26 AM
06/19/10 09:26 AM
Posts: 705 Michigan
Hemiroid
Whew! Glad to hear you caught it before someone got hurt
