Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: emarine01] #726564
07/19/10 11:29 AM
07/19/10 11:29 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Need a lot of Head/GEAR/RPM/stall for a Vic to show an improvement over an RPM or AG, especially in a heavier car and almost never in an 1/8th mile, motors just not in the sweet spot (above the flash and torque peak RPM)for enough of the time for it to pay off....if you don't have enough cam and head the Vic will never pay off becaue the extra airflow potential it has can never get past the valve.
Does a Victor have more HP potential?....you bet....but only when you got enough motor/rpm to need it. The M1 or old Strip Dominator makes better mid range than a Victor but not as good at the very top of the scale.
With an auto in a 3100 or so pound street car the RPM or Ag is tough to beat, as you get lighter or deeper geared the choice really depends on how much time the motor is over the torque peak.
WIZE
In Car:
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: Streetwize] #726565
07/19/10 11:49 AM
07/19/10 11:49 AM
Locomotion Offline
Locomotion  Offline
If you are just swapping manifolds without tuning on the jetting and especially the accellerator pump circuit, you are not making a valid comparison. A richer carb set-up will favor the single plane and a leaner carb set-up will favor the dual plane. The question is how is the carb is in relationship to the rest of your engine to start with.
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: Locomotion] #726566
07/19/10 12:11 PM
07/19/10 12:11 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I don't think you are giving the Victor a fair shot with out tuning the carb.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: Locomotion] #726567
07/19/10 01:11 PM
07/19/10 01:11 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I may leave the intake on for another go, but…being the skeptic that I am, I don’t think I will be able to get the 60’ times down to the same level as the Air-gap. I would need to pickup ~7 hundredths just to equal the Air-gap. The launch just feels too soft…throttle response is great, it just feels like it is down on torque.
The carb is currently tuned perfectly for the Air-gap, I assume the Victor will want a little more Jet and squirter?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: FlyFish] #726568
07/19/10 01:19 PM
07/19/10 01:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm thinking with a DA of +4000 feet that is where your missing power and torque went. Probally needed to lean it down a little because of the bad air.
Too bad you don't know what the DA was the last time you ran the AG.
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: Challenger 1] #726569
07/19/10 01:57 PM
07/19/10 01:57 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Some may think these results are flawed but I know quite a few people that have been amazed by the results with an rpm intake. I know greendart408 was running 10.8s with a very mild 408 with rpm intake. If I remember right it was 10.2 compression, ootb indybrocks,mp557 cam and 3050 pound dart.
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: viperblue72] #726570
07/19/10 02:12 PM
07/19/10 02:12 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Now i wonder if the hated torker II would be the ticket for a mild stroker?
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: FlyFish] #726571
07/19/10 02:19 PM
07/19/10 02:19 PM
bigsbigelow Offline
bigsbigelow  Offline
Did you swap for a Super Victor or Victor 340?
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: bigsbigelow] #726572
07/19/10 02:29 PM
07/19/10 02:29 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Victor 340
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: FlyFish] #726573
07/19/10 02:38 PM
07/19/10 02:38 PM
bigsbigelow Offline
bigsbigelow  Offline
Victor 340
Hmmm ok. I have one on my 340 and the motor really seems to like it. I haven't had it to the track but it pulls really hard all the way through the rpm range.
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: FlyFish] #726574
07/19/10 02:42 PM
07/19/10 02:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What was your normal 60' in the heat with the Air Gap? My Dart with a pump gas 340, hydraulic cam, ported Edelbrocks, Weiand X-Celerator, 4.30 gears, at 3300# went a best 1.530 60' and would go 1.55-56 in the heat.
The 10.9-1 408 in it now with the same heads, flat solid cam has gone 1.41 untuned with a Victor on it.
IMHO the X-Celerator is a very underated intake, I've seen them run hard on 340/360s and strokers too.
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: justinp61] #726575
07/19/10 03:05 PM
07/19/10 03:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Couldnt agree more about the excellerator, great intake that is way underated
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: justinp61] #726576
07/19/10 03:17 PM
07/19/10 03:17 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
On “normal” hot summer days it would run 1.53’s in the 60’ with the Air-gap….also, your car has a very similar combo (except a bigger cam and carb), but it goes ~3 tenths faster than my best (6.61 IIRC)…..weird huh?
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: FlyFish] #726577
07/19/10 04:02 PM
07/19/10 04:02 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Was any porting done on the victor?
Mine needed work right off the bat.The ports were smaller than a 318. I picked up 3 tenths switching a torker 2 to a victor and the torker had work on it also.
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: Scamp408] #726578
07/20/10 09:55 AM
07/20/10 09:55 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Yes, I port matched both the Air-gap and the Victor...The Victor needed more work, but looked good when I finished up.
I think I'll leave this intake on till fall, but if it doesn't pick up a LOT in the cool weather, it's coming off.
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: FlyFish] #726579
07/20/10 02:14 PM
07/20/10 02:14 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Not to high jack this thread but whats everyones opinion on the M-1 single plain??
