Re: Z-Bar Length?
[Re: RM21N0A]
#725740
06/16/10 11:24 AM
06/16/10 11:24 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Does anyone know the correct length of the Z-bar for both an A-body and B-Body?
Or else could you point me to where I could find out?
They wouldn't be the same length, would they?
Thanks.
Need more info to answer your questions. They are not the same length. Year / Model / Engine size Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
Re: Z-Bar Length?
[Re: RM21N0A]
#725742
06/16/10 01:23 PM
06/16/10 01:23 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Tube length should be 9" long with the bent arm welded approx 7 5/8" from the frame end. What bellhousing are you using and did you buy a new adjuster rod? Sounds like you have the wrong rod.
Re: Z-Bar Length?
[Re: RM21N0A]
#725743
06/16/10 01:25 PM
06/16/10 01:25 PM
Posts: 3,527 Lansing, MI
70gtx440dana
Lansing, MI
70 b body big block = 9 1/8".....
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Z-Bar Length?
[Re: RM21N0A]
#725752
12/21/11 08:58 AM
12/21/11 08:58 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
Is it possible that you've got the wrong fork? I've only worked with small block 4 speed setups, but I have a box full of spare parts and there's at least two different lengths of forks in there.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
Re: Z-Bar Length?
[Re: Publicbottle]
#725753
12/21/11 09:35 AM
12/21/11 09:35 AM
Posts: 531 Virginia
RM21N0A
Virginia
Publicbottle - I should have posted how I fixed it. Can't believe it's been a year and a half. A couple of days after my last post (July 2010) I went to the Carlisle Chrysler show/swap meet and walked up to the Brewer's Performance booth. I showed Dan Brewer the adjustment rod I was using and started to explain the problem, but he saw right away that I had the wrong rod. He put the correct rod on the counter and it had an angle (about 15-20 degrees) right after the end that connects to the Z-bar. Problem solved. I don't think that will help you though - it looks to me from your pictures that the angle you are dealing with is more like 30 degrees. Wish I had some suggestions for you, but maybe Evil Monkey has the solution with the length of the fork. Also, maybe Dan will see this post, or you could give them a call. http://www.brewersperformance.com/ Thanks again, Dan! P.S. - Publicbottle - I like that avatar. I'm a T. Rex fan from way back.
