Z-Bar Length? #725738
06/16/10 09:34 AM
06/16/10 09:34 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Does anyone know the correct length of the Z-bar for both an A-body and B-Body?
Or else could you point me to where I could find out?
They wouldn't be the same length, would they?
Thanks.
Re: Z-Bar Length? [Re: RM21N0A] #725739
06/16/10 10:16 AM
06/16/10 10:16 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Re: Z-Bar Length? [Re: RM21N0A] #725740
06/16/10 11:24 AM
06/16/10 11:24 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Thanks.
Need more info to answer your questions. They are not the same length.
Year / Model / Engine size
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Z-Bar Length? [Re: 64dodge572] #725741
06/16/10 12:23 PM
06/16/10 12:23 PM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Thanks for the fast reply.
1970 Road Runner, 383.
Just installed new ball studs and bushings last weekend, but seems like the Z-bar length is not long enough for the space between the ball studs.
The Z-bar barely covers the right ball.
This causes the clutch linkage rod to be at an angle between the Z-bar and the throwout bearing fork.
Does that make sense?
Any help you can provide is appreciated.
Re: Z-Bar Length? [Re: RM21N0A] #725742
06/16/10 01:23 PM
06/16/10 01:23 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Tube length should be 9" long with the bent arm welded approx 7 5/8" from the frame end. What bellhousing are you using and did you buy a new adjuster rod? Sounds like you have the wrong rod.
FAX 937-947-4419
Re: Z-Bar Length? [Re: RM21N0A] #725743
06/16/10 01:25 PM
06/16/10 01:25 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
70 b body big block = 9 1/8".....
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Z-Bar Length? [Re: 64dodge572] #725744
06/16/10 01:51 PM
06/16/10 01:51 PM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Thanks for the replies - I'll check the measurements as soon as I get home.
1. Bellhousing - on the car when I bought it 6 years ago. To answer your question, would I look for a casting number on it? Or take some measurements??
2. Adjuster rod - I did buy a new clutch linkage rod, but I still have the previous one, and they are the exact same. I had a post last week with a picture of the new one, along with the Z-bar bushings and ball studs.
I used all of the new parts, just kept the old Z-bar.
Other Z-Bar Post
Also, I explained in the other post that the old Z-bar never did sit right, due to the bent frame (where the U-slot is) that the left ball stud fits into.
I thought that after I straightened that out, it would sit right but I still have a bit of an angle between the Z-bar and the throwout bearing fork.
Re: Z-Bar Length? [Re: 64dodge572] #725745
06/30/10 08:12 AM
06/30/10 08:12 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
I need some opinions - is the clutch adjustment rod at too much of an angle in this picture?
I measured my Z-bar - it's about 9 1/16".
I was just hoping that after I installed the new nylon bushings on the 2 ball studs that the adjuster rod would be straight between the Z-bar and the pivot fork.
Re: Z-Bar Length? [Re: RM21N0A] #725746
06/30/10 08:13 AM
06/30/10 08:13 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
This is how it looks from the top - left side showing.
Re: Z-Bar Length? [Re: RM21N0A] #725747
06/30/10 01:49 PM
06/30/10 01:49 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Did you check the studs for proper placement?
Re: Z-Bar Length? [Re: Snoopy] #725748
07/04/10 04:52 PM
07/04/10 04:52 PM
Snoopy Offline
Snoopy  Offline
Pictures of the different z-bars.
Re: Z-Bar Length? [Re: Snoopy] #725749
07/07/10 08:35 AM
07/07/10 08:35 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Whoa. Musta dozed off there for a few minutes/days…
Thanks for the picture of the different Z-bars.
Looks like I have the correct one – the bottom one in the pic.
Also, yes – I triple-checked that I have the right pivot ball studs, and the long one is installed on the bell housing, short one on the left side.
I figger that if the clutch linkage rod is NOT supposed to be at an angle like in my picture above, then either:
1. The clutch pivot fork is a little short, or
2. I should have a different bell housing – one that would have the pivot ball mounting boss a half-inch or so further inboard. But then the ball would barely be inserted into the Z-bar.
Or, maybe everything is correct and the rod is supposed to be at an angle.
Here's another picture, showing how far the right side ball stud is inserted into the Z-bar, and to me it looks about right.
Any thoughts?
Thanks in advance.
Re: Z-Bar Length? [Re: RM21N0A] #725750
12/20/11 11:31 PM
12/20/11 11:31 PM
alberta
Publicbottle Offline
alberta
Diggin one outta the past..............just wondering if there was a fix for this? My fork adjust threaded rod is at a bit of an angle as well....is this ok or should it be more straight?
thanks!!
Re: Z-Bar Length? [Re: Publicbottle] #725751
12/21/11 02:14 AM
12/21/11 02:14 AM
alberta
alberta
here is a better pic...........
Re: Z-Bar Length? [Re: RM21N0A] #725752
12/21/11 08:58 AM
12/21/11 08:58 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
Is it possible that you've got the wrong fork? I've only worked with small block 4 speed setups, but I have a box full of spare parts and there's at least two different lengths of forks in there.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: Z-Bar Length? [Re: Publicbottle] #725753
12/21/11 09:35 AM
12/21/11 09:35 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Publicbottle - I should have posted how I fixed it. Can't believe it's been a year and a half.
A couple of days after my last post (July 2010) I went to the Carlisle Chrysler show/swap meet and walked up to the Brewer's Performance booth.
I showed Dan Brewer the adjustment rod I was using and started to explain the problem, but he saw right away that I had the wrong rod.
He put the correct rod on the counter and it had an angle (about 15-20 degrees) right after the end that connects to the Z-bar. Problem solved.
I don't think that will help you though - it looks to me from your pictures that the angle you are dealing with is more like 30 degrees. Wish I had some suggestions for you, but maybe Evil Monkey has the solution with the length of the fork. Also, maybe Dan will see this post, or you could give them a call.
http://www.brewersperformance.com/
Thanks again, Dan!
P.S. - Publicbottle - I like that avatar. I'm a T. Rex fan from way back.
