old style 8 3/4 question #725723
06/16/10 09:17 AM
06/16/10 09:17 AM
Tampa, FL
Garranimal Offline OP
Tampa, FL
Hey All,
I have a 55 belvedere that i have decided to put a 360 magnum motor in. My question is about the old style 8 3/4. It has the axles with the threaded holes for mounting the rims.....instead of the typical studs. It also has the old style round universal joint in the center section. Can I simply change the axles to newer style units and change out the pumpkin with a standard u-joint style? Can i use any of the standard bearings with this older setup?
After asking all of that, is there a direct swap from a newer vehicle?
I know, lots of questions....any help would be appreciated. Thanks
Re: old style 8 3/4 question [Re: Garranimal] #725724
06/16/10 10:02 AM
06/16/10 10:02 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, pre '57 rearends are obsolete.
I recommend swapping an 8 3/4" from a '65 and newer application.
What does your original rearend measure from drum to drum (overall width)?
Re: old style 8 3/4 question [Re: Garranimal] #725725
06/16/10 02:40 PM
06/16/10 02:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pre-'57 isn't an 8 3/4", it's an 8 1/4" and the 3rd member is attached with 11 nuts instead of 10 so they don't interchange.
Do like Doc says and swap in something newer.
Re: old style 8 3/4 question [Re: DoctorDiff] #725726
06/18/10 03:41 PM
06/18/10 03:41 PM
Tampa, FL
Tampa, FL
Dr. Diff,
Thanks for the response....i am away from the Belvedere this week......I will measure drum to drum this weekend and also the perch centers...
Thanks.
