Truck oil pan clearance #724426
06/14/10 06:44 PM
06/14/10 06:44 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Anyone know of any clearance problems using this pan in a 1969 GTX, its about two inches deeper then stock and holds a couple more quarts of oil, Thanks
Re: Truck oil pan clearance [Re: 69 GTX] #724427
06/14/10 06:47 PM
06/14/10 06:47 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Rear sump oil pans fit just fine if you dont need to STEER the car. The drag link occupies the same space as the sump of truck oil pans.
You need a mid sump car type oil pan. Trying to modify the car to fit around the wrong oil pan is like buying a small hat and then going to get your head shrunk!
Good luck!
Re: Truck oil pan clearance [Re: Kern Dog] #724428
06/14/10 06:51 PM
06/14/10 06:51 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Thanks very much, I will clean up the original pan and use it
Re: Truck oil pan clearance [Re: 69 GTX] #724429
06/14/10 08:05 PM
06/14/10 08:05 PM
scratchnfotraction Offline
you need the matching oil pick up tube for the center sump car pan also
yes the truck pan holds 6 qrts compaired to the 4 or 5 qrt car pans
some car pans are 4 and some are 5
my 88 gran fury car pan was 4 qrts
my 78 car pan was 5 qrts
IIRC anyways
just dont over fill it
