Little bit of valve ping from the 340 #722934
06/13/10 11:53 AM
06/13/10 11:53 AM
72greencuda Offline OP
Ive recently adjusted timing on the 340. 15 degrees initial 38 total. demon sizzled thermoquad ld 340 intake during this adjustment i plugged the vacuum advance. Motor fresh rebuild stock j heads, comp 284, 3000 stall 323 gear in 72 Cuda. When pressing pedal hard out of the hole i have nothing let up a bit and here we go, while driving 30mph punch gas four barrel opens with the sound of valve ping,My timing light is old. Thanks any help appreciated.
Re: Little bit of valve ping from the 340 [Re: 72greencuda] #722935
06/13/10 11:59 AM
06/13/10 11:59 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Back the timing off until the detonation goes away.
Re: Little bit of valve ping from the 340 [Re: 72greencuda] #722936
06/13/10 12:00 PM
06/13/10 12:00 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Back the timing off slightly and see what happens. Never heard of the valve ping term though
Re: Little bit of valve ping from the 340 [Re: MoparforLife] #722937
06/13/10 12:25 PM
06/13/10 12:25 PM
you should be around 30-34* degrees total advance w/o vac can hooked up.
what kind of cranking psi does the motor have?
