Re: Manual Steering Box Lube?
[Re: Kern Dog]
#722087
06/12/10 10:56 AM
06/12/10 10:56 AM
Posts: 1,095 Bloomington, Illernoise
cptn60
They were packed with a grease from the factory. I can't remember the spec for it, however. Maybe a good long fiber stiff grease would work. ?
This space available for rent
[Re: cptn60]
#722088
06/12/10 03:50 PM
06/12/10 03:50 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The original lube that Mopar called "steering gear grease" is actually a really heavy fluid (600 weight), regular chassis grease is recommended to top off only if the correct lube isn't available.
[Re: John_Kunkel]
#722089
06/13/10 02:50 PM
06/13/10 02:50 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
Regular chassis grease is what we used back in the day at my Dad's gas station. One of the Mopar rags had a article on rebuilding boxes and mentioned that the factory stuff was so heavy that it had to be heated so that it could be more easily poured into the box.
[Re: Reggie]
#722090
06/13/10 05:31 PM
06/13/10 05:31 PM
John_Kunkel
Rio Linda, CA
The article you refer to used a combo of chassis grease and 90 wt oil which needs to be heated to flow, the original heavy oil flows at room temperature.
Mac's Auto Parts in Lockport, NY has the correct 600 wt steering box lube.
