Re: E-85 or Race Fuel
[Re: Fast Yeti]
#721765
06/12/10 08:41 PM
06/12/10 08:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks Mike. Can you leave e85 in your fuel cell and lines for extended periods of time or does it attract water? Are you refilling an old race fuel can to store the e85?
I leave it in the system all winter... I have a 30 gal steel fuel drum that I store my fuel in(its sealed when not in use... when I want fuel I have a hand pump I screw into the drum... get what I want(usually 5 gals) then screw the bungs back in so its air tight The fuel that I leave in the system I think keeps my gaskets from shrinking(at least it has so far) I fire it up in the spring with that fuel and get it all warmed up real good then drain the little bit thats left and then open my filters and check and clean if needed(my pre pump filters) and check the after pump filter... then fill with fresh fuel(still left over from the previous summer in my fuel drum) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Fast Yeti]
#721767
06/12/10 11:07 PM
06/12/10 11:07 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Any cooling system changes needed? Can you go to a smaller radiator ie like running straight methanol?
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: MRMOPAR]
#721768
06/13/10 12:02 AM
06/13/10 12:02 AM
MR_P_BODY
I didnt... I keep the whole cooling system the same, I just leave the fan and pump off a little longer then turn on the pump and wait till the temp is up to 160 for the burnout... after the burnout I turn the fan on for the pass... at the end of the pass I'm at 180 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#721769
06/13/10 12:07 AM
06/13/10 12:07 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
Can't wait for some E85 in Ontario Sounds like the sweet ticket. I wonder if I can run 10:1 compression with a procharger and E85?? ![](/ubbthreads/images/graemlins/crazy.gif)
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#721770
06/13/10 12:36 AM
06/13/10 12:36 AM
MR_P_BODY
I would think thats still to much... even for E-85 but if you feel like trying... go for it but make sure you can detect detonation and quickly ![](/ubbthreads/images/graemlins/wave.gif)
[Re: v8punch]
#721772
06/13/10 11:00 AM
06/13/10 11:00 AM
Posts: 16,932 NC
440Jim
NC
I have heard that the fuel ethanol that is sold in Brazil is not dehydrated (water removed). In the United States, the ethanol is dried, so that they can put gasoline in solution. Once you reach a certain level of water in solution, gasoline will separate. And the water in the ethanol can create higher corrosive conditions. I don't know how accurate that information is, just heard it. What does fuel ethanol sell for in Brazil? I will have to convert the currancy. In the U.S. E85 is about $2.30/gallon, and finding a supplier of high percentage fuel ethanol (E98) is not easy and I am not aware of any within 100 miles of me. http://www.x-rates.com/calculator.htmlAnd 3.7854 liters per US gallon
[Re: MR_P_BODY]
#721773
06/13/10 11:06 AM
06/13/10 11:06 AM
Posts: 16,932 NC
440Jim
NC
I don't run the cooling fan on my race car going down the track. In fact, I don't use the fan much at all! I actually lean the mixture with the fan off to put heat in the motor, I like to stage at 170F. I could use a smaller radiator, but this works for me.
My experience running race gas, E85 and methanol is that E85 cools more than gas, but not as much as methanol. That makes sense since you are not burning as much E85 as methanol, which evaporates and cools the motor in the intake ports.
[Re: Fast Yeti]
#721776
06/13/10 12:23 PM
06/13/10 12:23 PM
Posts: 85 europe
WBR
europe
Donīt mean to hi jack but... Iīm converting my sb 360 to E-85 and bought the quick fuel conversion metering blocks for my holley 750vac. javascript:void(0)Didnīt work out very well probably due to the lack of changeable airbleeds. Can i get it to work with a pro form main body and for a starting point jet it like a QF carb. Iīd also really want to make it a double pumper. What would it require Besides the main body?
Street driven, 421 Sb, NA, 9.98/137
[Re: MRMOPAR]
#721780
06/13/10 04:36 PM
06/13/10 04:36 PM
MR_P_BODY
on your pump you need to make sure that it can flow 30% more volume than it did over gas...
How about... what fuel pumps are you E85 guys running, rather than 30% more. That number is not really instructive to a lot of readers.
I run a pair of Holley black 150s... will depend on how many revs or how big of a carb... I know that my pair of 150s is more than enough... I run a QF 1050 dom for E-85 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#721781
06/14/10 07:16 PM
06/14/10 07:16 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
2 holley blues in my car (10.0's)
1 holley blue on my dads car (11.0's)
both set at 6 psi
WAXER
[Re: ProStDodge]
#721783
06/15/10 08:43 AM
06/15/10 08:43 AM
Posts: 404 Dana Point, CA
Fast Yeti
Dana Point, CA
For the most part - I like the prospects of E-85 and am considering using it for my current EFI project. HOWEVER keep in mind, NHRA considers E-85 as "alcohol". If running alcohol faster than 9.99 with a supercharger or turbo, a 3.2A/15 firesuit is required instead of a 3.2A/5 suit for race fuel in the same car.
Scott, what about NA combos? ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Fast Yeti]
#721784
06/15/10 11:04 AM
06/15/10 11:04 AM
Posts: 1,178 Indy
FlyFish
Indy
When running 2 fuel pumps, like 2 Holley black pumps, do you connect them in series (on one line) or have them each on their own dedicated fuel line?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
