I have been noticing a troublesome gremlin that I can't get figured out. After a full throttle pass for several seconds my RPM's won't come down very much. Happened at a race first then a couple times on the street. Pedal returns to normal position and the linkage all comes back to home but I think the secondaries are sticking open a bit.
Doesn't do it unless there is a load on the engine (can't repeat it in the shop). Everything seems to be working fine and the butterflies are well centered on the manifold, no gasket interference, linkage interference, etc..
Anyone ever run into this problem with Eddy's???? I want to head back to the strip this Sat but I need to get this problem figured out first!
