need timing & jetting recommendation - methanol (UPDATE
#721143
06/11/10 10:39 AM
06/11/10 10:39 AM
Posts: 481 Cheswick, PA
Bob_Spelic
Cheswick, PA
I have just switched my dragster over from gas to alcohol (methanol). I have a couple of questions about timing and spark plug choice. The engine is a 572 with 440-1 heads, Ross Flat top pistons, 14:1 compression, APD alcohol dominator carb on a 440-2 indy intake.
The timing that I found to be about optimum for 110 race gas was around 35 to 36 degrees.
When on alcohol, do I leave the timing in this range or do I increase or decrease it?
I have been running NGK -8 plugs for 110 race gas. Do I run a hotter or cooler plug for alcohol?
bob Spelic
Re: need timing and spark plug recommendation - methanol
[Re: Bob_Spelic]
#721144
06/11/10 11:09 AM
06/11/10 11:09 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Indy told me to run Champion C59CX plugs in mine. They seem to work well,also I have run my timing @ 35 degrees so far. I am still learning how to run alcohol,but so far its been great. There are a lot of others on here that hopefuly can help you a little better. Maybe we can compare tune ups as we both get our set-ups right.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: speedy383]
#721147
06/11/10 07:51 PM
06/11/10 07:51 PM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
When I swithed from gas/carb to alky/Toilet a few years back I kept the #8NGKs in and left the timing at 38degrees and it ran great, Combo; 500" w/ IndyEZ-1s. Since then I have switched to NGK#9s with no noticable difference and run my timing at 35-36degrees. best of luck with it. Curtis
Taking over the World one win light at a time.
[Re: MegaDart]
#721150
06/12/10 04:06 PM
06/12/10 04:06 PM
MRMOPAR622
Sweet Home Alabama
The Mopar engines seem to want more fuel than the Chevy's. James Monroe says he has Chevys that make HP and take less fuel than mine.
[Re: MRMOPAR622]
#721151
06/14/10 10:18 AM
06/14/10 10:18 AM
Posts: 414 No. cal., sacramento usa
speedy383
Had been running 33. This weekend tried 35, engine temp came up quicker which is good and egt dropped slightly to 1100 picked up acouple of hundreds to 330,but hard to compare as it was 95 degress and marginal track. Then went to 37,engine temp up noticeable and egt way up,1250/1300. So I will probably stay at 34 which is about the same as is i was running gas.I parked next to a super comp olds running off the stop 8.30,says he never goes above 35,this is a 622 chevy.I am only at 440 cu,around 775 hp,15/1 720 roller,so the answer is eeach engine has different needs based on a lot of factors ,i would be conservative and err on the side of caution.
[Re: speedy383]
#721152
06/14/10 03:32 PM
06/14/10 03:32 PM
Bob_Spelic
Cheswick, PA
I raced this Thursday at a test and tune, and I started at 30 degrees and 177 jets. Bad miss past the 1/8th mile marker. Increasing to 188 jets and miss went away and performance was a 8.15. Went to 196 jets and no miss but slowed to 8.18. Changed to 35 degrees and car slowed to 8.20. I could not get over 160 degrees with just running the water pump.
Saturday I left timing at 35 and lowered jetting to 192, Different day and different weather, performance was a 8.18, and 8.14 then an 8.20....no consistency! Sunday tried again with no changes, 8.18, 8.14, 8.17. I still cannot get any more than 160 degrees even with a lean out valve. I still think it's moving around too much and not generating any heat has me concerned I'm still way off in tuning.
Do you think I should go to 188 jets and leave timing alone or mess with both?
Thanks for all that responded!
Bob Spelic
[Re: Bob_Spelic]
#721155
06/14/10 09:09 PM
06/14/10 09:09 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I cant reccomend a carb tune, but I did run a very similar combo in a digger also. Same heads, intake a hair more compression 20 or so less cubes. My engine was very sensitive to plug gap..Note that if I increased gap to .040+ the car would slow near a tenth. I ran a old self modified Toilet injection. The car was a easy mid to high 7 second car in the middle of July. So there should be a little more left in your combo. My engine/drivetrain was thrown together by me with swap meet parts and self tuned. Pretty large learning curve but I overcame most. I really felt it should have been a half a tenth faster though.. The converter I was using was all wrong, which it was a friends made custom for his small block Chevy car @ about 3000 lb car. It worked OK. The car 60ft in the 1.06-1.07 range, no matter what track I took it too. The last pass it went 145+ in the 8th down at the Clay City Ky Mopar Southrn Classic show... Anyways. The temps is a good tuning tool for a alky car. The car should gain about 6-8 deg in temp from the launch to the stripe. As soon as you let off the throttle it will cool. My car would burn 2 1/2- 3 gallons per pass from the pit to pass back to the pit, depending on where I run..Like clay city has a long return road etc.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#721156
06/15/10 12:07 AM
06/15/10 12:07 AM
Posts: 903 Saskatchewan, Canada
cudabin
My 440-1 heads ran the quickest on "gas" at 35 - 36 degrees.
Switched to a Terminator on meth, and on the Dyno the best power was at 36 degrees...
They tried 34 and lost a bit, and tried 38 and it was about the same as 36, so no sense stressing the bottom end,
440 Jim did some timing testing at the track, so maybe search for his post.
Good luck!
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
