who makes the best frame connector?
#720746
06/10/10 06:11 PM
06/10/10 06:11 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Guys
Who would you suggestion for Frame connectors? I'm going to oput them in before I even start mewessing with the caltracs.
Mike
PS I don't want to mess with moving the springs into the longetudials
1969 Dodge Dart Swinger
Re: who makes the best frame connector?
[Re: MikeyT]
#720747
06/10/10 06:14 PM
06/10/10 06:14 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Me. I liked some of the kits I have seen , but it was way cheaper and just as easy to fab my own. I think it is U.S. Autobody that has a set that follows the contours for the underside of the floor pan. I cut into the floor in front of the back seat and used 2X3 tubing from the rear of the transmission cross member to inside the front of the rear sub frame.
[Re: tubtar]
#720748
06/10/10 06:30 PM
06/10/10 06:30 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The xv ones I used on a challenger took about 8 hours to fit and weld in. They look good when done, but sure was alot of grinding. On my own challenger I'm just taking some square tubing and making my own. The ones mp sales are the easiest to install, they bolt in, but I welded them also on my 69 and 70 runners.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: The Shocker]
#720751
06/10/10 07:56 PM
06/10/10 07:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I used 2" X 3" X .125 to make quite a few sets... frame ties and 8 3/4 back braces for a little side money to help pay for parts
[Re: Sledge_57]
#720754
06/15/10 04:40 PM
06/15/10 04:40 PM
MR_P_BODY
Need some more parts Mike?
Why Doug... do you need a set installed?
[Re: 71Dusterdan]
#720756
06/15/10 05:51 PM
06/15/10 05:51 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Round tubing here and make my own. Have done hundreds. No floor cutting or anything
JAKES AUTOMOTIVE
[Re: JAKE68]
#720758
06/25/10 09:17 AM
06/25/10 09:17 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I thought I was the only one using round tubing. Cost less than $30, not including the beer.
Here's a pic.
codfish
[Re: greenpigs]
#720763
10/23/10 10:53 AM
10/23/10 10:53 AM
Posts: 4,210 New York
polyspheric
New York
wonder why people use the 2X3 instead of the 2X2?
Because it's much, much stronger.
Boffin Emeritus
[Re: smokinwoody]
#720765
10/23/10 12:09 PM
10/23/10 12:09 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I have the Competition Engineering bolt in connectors, now welded in. They fit perfectly, I was happy with them.
