70 Bee overdoor"foam" seal needed #720678
06/10/10 03:40 PM
06/10/10 03:40 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
I'm replacing the overdoor seals and removed the s.s. trim,I noticed there is a black foam style seal.....Does anyone know where to get it?? Wjat should I use..silicone?? Thanks for any and all help..
Sorry my camera's down,I'll update later.
Here's the seal,it's black and a thin foam type..
Re: 70 Bee overdoor seal [Re: Hemiruss] #720679
06/10/10 04:40 PM
06/10/10 04:40 PM
okla.
O
okie Offline
okie  Offline
O
okla.
DMT He is a member on here, he has all the seals and gaskets anyone needs. I think on here he goes by 71TA. He sells good stuff and ships fast. Good Luck! Ronnie in Okla.
Re: 70 Bee overdoor seal [Re: Hemiruss] #720680
06/10/10 09:09 PM
06/10/10 09:09 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
2nd
Re: 70 Bee overdoor"foam" seal needed [Re: Hemiruss] #720681
06/11/10 11:24 AM
06/11/10 11:24 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I guessed wrong in the PM to you.
Those are the 66-70 B body black plasticy polyethelene foam strips about 3/16"T x 7/8"W. Yep. I have them in a kit. Have them custom cut to thickness in sheets then slit to width.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
