Post deleted by Defbob
[Re: FrozenDuster]
#720181
06/10/10 10:57 PM
06/10/10 10:57 PM
#720182
06/10/10 10:57 PM
06/10/10 10:57 PM
Re: considering rear mount twin turbos, pros and cons?
#720183
06/11/10 08:49 AM
06/11/10 08:49 AM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
We have tuned several rear mounts and really like the cleanliness it gives the engine bay. The oil supply is the only real addition as mentioned above. Generally the oil has been supplied by a separate pump and tank in the rear eliminating use of and plumbing to the engine oil. As far as additional piping, there really isn't that much more especially if a customer is running an A/W intercooler. In your low boost application you may not need an intercooler (as was mentioned previously) but trust me, you will become a "boost junky" and 10psi will not be enough. Here are some videos of cars w/rear mounts we have tuned. They run well, make plenty of power, little to no lag and very clean installs. http://www.youtube.com/watch?v=YoJ9EZ2I96Ehttp://www.youtube.com/watch?v=VAzXgHH_2m0Here's a link to the Lemans's feature in HotRod magazine. There's some good pictures of the turbo install, the engine bay etc. http://www.hotrod.com/featuredvehicles/hrdp_0711_1963_pontiac_tempest_lemans/index.html
[Re: 1badx]
#720184
06/11/10 09:56 AM
06/11/10 09:56 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
could yuo just run meth/H2O injection and forget about the cooler???? I'd think for somebody with limited welding skills the trunk mount would be the way to go.
