Re: Spark Plug Reading? Burning oil or Rich?
[Re: Blue69Charger]
#719552
06/08/10 11:00 PM
06/08/10 11:00 PM
RapidRobert
definitely burning oil (blue smoke and plug appearance) and may be rich also. I'd check the float levels and the PV's for the richness but #1 is where the oil is being sucked in at
[Re: Blue69Charger]
#719556
06/09/10 11:31 PM
06/09/10 11:31 PM
RapidRobert
I like Permates "high tack" the red stuff in the spray can. it goes on evenly, is thin, is easy to apply & is super tacky and seals well. Most any type of sealer works well except silicone though I think there are several varieties of it that are fuel resistant but myself I dont like to use it there.
[Re: RapidRobert]
#719557
06/10/10 12:31 AM
06/10/10 12:31 AM
Posts: 5,166 CT
GTX MATT
CT
If those are composite I'd try some different gaskets.
[Re: Blue69Charger]
#719559
06/12/10 10:44 PM
06/12/10 10:44 PM
try wiping a thin skin of rtv below/across the bottom of the intake ports next time, for insurance.
