*UPDATE *Mopar guru's- Mystery noise and some questions
#719490
06/08/10 09:46 PM
06/08/10 09:46 PM
Posts: 1,630 North Central Florida
eightlitermopar
71 RR with 383 engine was rebuilt 10 years ago, low miles since then. First of all, it runs great, however, I have developed a "tick" or a "knock" when the motor is at an idle when IN GEAR. Park and neutral it disappears. Oil pressure is awesome. 50 PSI at idle. possible #1) Torque converter bolts. I took off the cover, all 4 bolts tight. Started with the cover off, knock is still there in gear. possible #2) Comp XE valvetrain. I suspected a noisy valvetrain. I even swapped the roller rockers for stock stamped ones. Still there. Maybe a lifter? Now, for the question I haven't really addressed. When this motor was done, the crank journals were align bored. This has left my timing chain "loose" or with some slack in it. It is not sloppy, but I even swapped timing sets, still has a little play in it. When timing the initial, it occaisonally with jump around 1 degree on the dampner with the timing light. I have wrapped this motor to 6500 rpm with no problems, however the slack has me a little concerned especially since I think it may have to do with my "piston slap/knock/ tick/ whatever when in idle. Give it a little gas and it goes away. So, where should I look first to get rid of this crappy noise and #2, for those who align bore the crank journals, how to overcome or eliminate the timing chain "slack". I know I can't be the only one to experience this. thanks again! eight
Mopar or no car
Re: Mopar guru's- Mystery noise and some questions
[Re: CARMAN]
#719493
06/08/10 11:02 PM
06/08/10 11:02 PM
eightlitermopar
thanks for the response... I am not terribly worried about the noise, but it does bug me (and it's embarassing) sitting in traffic. I ruled out valve train due to it occuring when in gear, but I've been wrong before Anyway, I will look into some of those timing chains, I'll throw one on with my next cam swap. anyone else? eight
Mopar or no car
[Re: RodStRace]
#719496
06/09/10 03:31 PM
06/09/10 03:31 PM
eightlitermopar
Good job asking the question; lots of info. A couple questions to define it even better.
1. Oil pressure the same at idle in gear and in neutral? yes A. What brand/weight oil and filter? I think it currently has supertec oil from walmart, synthetic blend. I usually run 20/50 or 10/30. Oil filter is a fram tough guard, I know, I know, fram sucks. The noise was still there when I had a WIX on it as well. B. Have you tried thicker oil? 20/50 is as thick as I have gone
2. How much does the RPM drop in gear? yes, 100-150 rpm drop. In gear it idles about 700-800
3. If you raise the RPM in gear to what it is in neutral or a bit higher (1200-1500), does the noise go away? As far as I can tell. It seems to, but to be honest it is hard to tell because I have dual flowmasters on it.
4. Is it exactly RPM related? If so, is it say 800 Beats Per Minute (same as crank RPM) or more like 400 BPM, more like cam/valvetrain/power strokes? It honestly seems faster than the crank, which is another reason I thought it was cam or valvetrain. I also suspect TC bolts because of this. If I have 4 bolts hitting something per 1 revolution of crank, for example.
Anyway, I will keep looking at it. It seems like it is coming more from the drivers side bank side of the motor. I have a stethescope which I used, but I couldn't pinpoint anything from that on the motor from up top.
I will put it on the ramps and double check the tranny. I really don't want to have to pull headers and transmissions for a new flex plate if something is messed up there!
The noise will be less at times, then other times it will be very loud and pronouced. It seems to be worse when the motor is warmed up.
Then it will go away for a while. I don't need a mechanic, I need a priest! this car is posessed!
any more ideas? I will keep you posted.
eight
Mopar or no car
[Re: '72CudaRacer]
#719498
06/09/10 06:45 PM
06/09/10 06:45 PM
eightlitermopar
I know....maybe deep down I am hoping it really is something simple instead of a rod knock or something like that. the tranny is a TCI unit which everyone does not like. It's lasted 6 years....maybe it's starting to fall apart? I honestly cannot think of anything else p.s. does anyone have a part # or location I can get a shorter timing chain for an align bored block? thanks
Mopar or no car
[Re: eightlitermopar]
#719499
06/09/10 06:57 PM
06/09/10 06:57 PM
Posts: 7,664 IN
ahy
IN
From Summit
Cloyes Gear 9-3125-5 - Cloyes Original True Roller Timing Sets
large image Image is a representation of this part. Actual part may vary. $125.95
+ Wish List + compare Timing Chain and Gear Set, Original True Roller, Double Roller, Iron/Steel Sprockets, Mopar, Big Block, Set Application Specific Part: Check Application Estimated Ship Date: 6/24/2010Email this page Share OverviewApplicationShow AllLarge Image Brand Cloyes Gear Manufacturer's Part Number 9-3125-5 Part Type Timing Chain and Gear Sets Product Line Cloyes Original True Roller Timing Sets Summit Racing Part Number CLO-9-3125-5 Timing Chain Style Double roller Camshaft Gear Attachment 3-bolt Maximum Advance/Retard at Camshaft 2 degree Maximum Advance/Retard at Crankshaft 4 degree Thrust Bearing Included No Offset Bushings Included No Gaskets Included No Bolts/Studs Included No Cam Sprocket Material Iron Crank Sprocket Material Billet steel Quantity Sold as a set. Notes Will not fit factory roller camshaft applications, length reduced by -0.005 in.,
UPDATE: Mopar guru's- Mystery noise and some questions
[Re: ahy]
#719500
06/09/10 11:25 PM
06/09/10 11:25 PM
eightlitermopar
Thanks for the part number AHY, I'll definately look into that. Ok, so I reluctantly pulled the roadrunner on the ramps and started poking around. 1) Took the transmission cover off. Looks good 2) Visually inspected each TC bolt. No scrapes or rubbed edges. 3) I spray painted each bolt, restarted the motor. Noise is definately there. 4)rechecked each freshly painted bolt. No paint scraped from any of the bolts. 5) The noise is definately coming from the rear engine/torque converter area. I started the motor, put in gear at idle with parking brake and wheels blocked. I got a mirror to make sure the transmission case wasn't bent on the bottom side and making contact with the ring gear. no scuffs on the case, teeth on converter are free of damage or rubbing. 6) Grabbed my stethescope. Listened around on the oil pan and block. I hear engine noise but nothing abnormal. Transmission case and engine sounds the same. So...Here are my stabs in the dark. what do you think? 1)It is a mopar performace torque converter, 2300-2400 stall if I recall correctly. Could the inner fins be messed up or slightly "slipped" to make contact, resulting in a racket ONLY when in gear? I know very little about torque converters and what innards could fail. 2) The transmission is the beloved TCI streetfighter tranny. Could a tranny pump or somthing be slightly off, causing the noise? 3) The TCI transmission is messed up so that back of the TC is rubbing the case somewhere. I would only confirm this by dropping the tranny and taking a poke around with a stick. Anyway, thats the update for your reading pleasure. If you have any ideas or experience with this stuff, let me know. Thanks again! eight
Mopar or no car
Re: UPDATE: Mopar guru's- Mystery noise and some questions
#719506
06/10/10 03:04 PM
06/10/10 03:04 PM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
quote: "1)It is a mopar performace torque converter, 2300-2400 stall if I recall correctly. Could the inner fins be messed up or slightly "slipped" to make contact, resulting in a racket ONLY when in gear?"
I had a B&M converter fail internally and cause symptoms similar to your problem. I had a crank-speed tick that sounded exactly like loose flex plate bolts, but my noise was intermittent... it didn't do it every time I drove the car. The converter still performed well, it just made a noise that would come and go at first, and later did more staying than going. My pan magnet DID look like Beeker every 200 miles or so. I let it go too long and the converter wiped out the stator support and the input shaft....
Re: *UPDATE *Mopar guru's- Mystery noise and some questions
[Re: ERAT340]
#719508
06/11/10 12:30 AM
06/11/10 12:30 AM
eightlitermopar
Yeah, I might pull the car back up on the ramps tomorrow and take a better look.
To me it seems the noise is more tranny/back of motor related, but I will look at the headers while I am at it. They are heddman elites and did have to be "pursuaded" to fit in perfectly. Maybe hitting barely against the starter or something.
I want to pull the tranny plug first though, and see what kind of "fuzz" I have on the magnet.
I usually can find exhaust leaks pretty good by running the motor and getting it warmed up, then dumping sea foam down the carb. I have seem many puffs of smoke in the past which I was able to fix with this method. Maybe it's time for another round...
I'll keep ya posted....
sigh
eight
Mopar or no car
