Re: 318 timing and or carb
[Re: Mopar_Country]
#719466
06/08/10 09:14 PM
06/08/10 09:14 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
The electric fuel pump won't help the hesitation, I'm guessing this is an A body - that's a lot of cam for 2.76's and a stock converter, try the gears first since it's kinda dead below 2k, if that doesn't cure it throw in a 2,200-2,400 converter.
I would run more gear if it were my car - 3.91-4.10 with a 26" tire will wake it up.
If you feel like messing with the carb and distributor first recurve the dist for 18-20* at idle, 36* max and make sure the acc pump in the carb is good and adjusted right, you can move the arm around to get more or less pump shot. I like the older leather plungers in T-quads, I tried the rubber one in my truck and it never ran right for me, I soaked the 35 year old leather plunger in motor oil for a few days and threw it back in, it solved a bunch of my driveability problems.
[Re: Mopar_Country]
#719467
06/08/10 09:19 PM
06/08/10 09:19 PM
RapidRobert
That is not a long post, you must be new . 1st check for adequate AP squirt. Is this a WOT hesitation or as your rolling into it and might want to note the vac in hg at that point. What initial timing? ported or vacuum? What yr of TQ (some are pretty lean). Might termporarily block the metering rod tree "up" so it is on the power step and take it out to see if the main metering is too lean and causing this.
[Re: RapidRobert]
#719471
06/09/10 09:02 AM
06/09/10 09:02 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
timing with that cam, I'd go as others said, 18-20 intital, 36ish total.
I'd also run a converter in the 2200-2400 range.
since it's better when you snap the throttle, I'd imagine pump shot is OK, if it's tip in, not sure where to check with a t-quad, do they have step up springs like an AFB/AVS? if so, maybe they need to be slightly stiffer...or maybe the rear air door is adjusted too loose so it is opening at light throttle applications, leaning it out?
[Re: Mopar_Country]
#719475
06/09/10 11:10 PM
06/09/10 11:10 PM
RapidRobert
Assuming no vac leak, richer rods and or jets but probably larger jets. I tried to find Demonsizzlers cell # and I misplaced it. He's the TQ guru out of Atlanta Georgia and the one to contact. His contact info may be in the archives. EDIT I remembered that he is hard to get ahold of sometimes. Might see what jets you have and put an add in the wanted ads here and find a pair of larger ones than what you currently have in there.
