Question about Holley billet fuel pumps..............
#719228
06/08/10 03:05 PM
06/08/10 03:05 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
My billet hp-150 decided to start leaking the other day and I was curious if anyone else has had this problem and if so did you rebuild it(if possible)or send it back or toss it. Thankxxx....
Re: Question about Holley billet fuel pumps..............
[Re: JUST_N_TIME]
#719231
06/08/10 11:29 PM
06/08/10 11:29 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Maybe they make a seal kit for it?
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: JUST_N_TIME]
#719232
06/08/10 11:46 PM
06/08/10 11:46 PM
Thumperdart
State of confusion
I dove into it and it`s pretty simple enuff but after visiting the bullet and reading horror stories about the pump gas w/ethonol and how it`s jacking up rubber components,I wonder if a different pump would be the hot ticket. What I found was the bearing on the shaft that turns the gears has a rubber seal that keeps fuel out of the motor by puking out of the weep hole well, it puked out of the weep hole which tells me it`s no longer sealing and it`s part of the lower body on the pump so doesn`t look replaceable....... Just for giggles I filled the puke hole w/a bb and silicone and will check it in the morning but my concern is that fuel may now head up into the main body electrical area and cause havock......I`m strongly looking at the Mallory 250 bypass pump.
[Re: 68 HEMI GTS]
#719236
06/09/10 01:15 PM
06/09/10 01:15 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
That sucks Dom. I know where your coming from though... Worse fuel pump I have ever purchased period. I asked around and these pumps are really horrible. Matter of fact the guy on this thread is the only one I have heard that hasnt had any trouble yet. I spent a hour on the phone with a Holley tech guy, he said in not so many words, his entire day is spent on the phone talking to guys about this fuel pump alone. I think It was on the truck for less than One week, before i wised up and sent it back to Summit racing for a Mallory 140 pump... Not much better it eats brush's like clock work every 3 months. The coomutator is worn so bad from the brushes there is about a 3/16 step were the brush rides around it. I really like how the pump worked, and it was super quite. My Holley pump the relief valve/plunger kept hanging up. The fuel pressure would swing quickly and violently from 5 to 14 psi like a flag blowing in the wind.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Thumperdart]
#719238
06/09/10 02:51 PM
06/09/10 02:51 PM
Posts: 419 NY
F1Scamp
NY
Yeah I have had both the 125 and the 150. Neither of which made it a full pass without making the car's nose over. The 125 had an output of less than 50gph, with 15v's to it and nothing in front of it. With any kind of line in front it was around 40. Talked with holley tech support, "never heard anything like that, these pumps are really good..." JUNK
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: Thumperdart]
#719239
06/09/10 02:57 PM
06/09/10 02:57 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
If you want to keep a simple dead head system that will still feed your combo, I'd recommend the Aeromotive street rod pump. It's their smallest one but it works really well. It fed my car up until 2 weeks ago when I upgraded to a return style system using the A1000 pump. Only reason I upgraded was I started having issues with vapor locking when I drove the car on hot days.
[Re: Thumperdart]
#719241
06/09/10 04:33 PM
06/09/10 04:33 PM
Posts: 2,923 A shed in England
Tig
A shed in England
I've only recently upgraded to a 250 from the 150. It was on for 10 years and no problems. It's now the spare.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Thumperdart]
#719243
06/09/10 04:49 PM
06/09/10 04:49 PM
Tig
A shed in England
Didn't they used to call these pumps the "dominator" series? I could be mistaken.
[Re: Thumperdart]
#719245
06/09/10 05:05 PM
06/09/10 05:05 PM
Tig
A shed in England
[Re: Thumperdart]
#719247
06/09/10 05:26 PM
06/09/10 05:26 PM
Tig
A shed in England
Is this the one? http://www.holley.com/12-150.aspLooks like I got mixed up. My bad.
