New Star Vacuum pump installed ! #718748
06/08/10 12:06 AM
06/08/10 12:06 AM
Saskatchewan, Canada
cudabin Offline OP
cudabin  Offline OP
Just finished installing my new Star vacuum pump.
Had to move the fuel pump and get some unique sized belts, but it looks good to me, and I am now ready to start the motor tommorow night and hear what 900 ponies sound like.
How does this install look???
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: New Star Vacuum pump installed ! [Re: cudabin] #718749
06/08/10 12:08 AM
06/08/10 12:08 AM
cudabin Offline OP
cudabin  Offline OP
#2
Post deleted by Defbob [Re: cudabin] #718750
06/08/10 01:34 AM
06/08/10 01:34 AM
Re: New Star Vacuum pump installed ! #718751
06/08/10 01:39 AM
06/08/10 01:39 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I never knew that about star pumps..good thing to know...
Fred...can a Moroso pull thru a filtered canister too??
found what I needed... http://www.starvacuumpumps.com/products/STR.02.09.00AN
Post deleted by Defbob [Re: smokinwoody] #718752
06/08/10 01:56 AM
06/08/10 01:56 AM
Re: New Star Vacuum pump installed ! #718753
06/08/10 06:28 AM
06/08/10 06:28 AM
Nazareth,Pa.
JACKSON Offline
JACKSON  Offline
Nazareth,Pa.
HOW much do the star filtered cannisters cost?i guess i'll need one too?
mine is plumbed wrong also.
Re: New Star Vacuum pump installed ! #718754
06/08/10 07:47 AM
06/08/10 07:47 AM
Out West
408strokerdart Offline
Out West
Did you buy it used ? It is missing a very critical part the seperator tank.
I have the mountain motor version. this is the first installation that I have seen that does not use their tank.I felt one of if not the main advantage of the Star units was in it being non lubricated and also using that tank . Why would you want to pull thru the pump when Star puts an emphasis on keeping the pump dry and oil free? The way it's now routed oil and dirt will wind up inside it for sure and do it harm.
When then tank is used everything in drawn thru the tank's filters before getting to the pump itself.This will keep pump life at a very high level .Other designs need much more attention and frequent rebuilds due to dirt going thru their vanes. Star will not warranty the pump unless the tank is used. You should seriously consider getting one before you hurt the pump.
Mine has the seperator and I have never seen a Star installed without it.
Re: New Star Vacuum pump installed ! [Re: 408strokerdart] #718755
06/08/10 10:00 AM
06/08/10 10:00 AM
cudabin Offline OP
cudabin  Offline OP
I bought it new as a kit, (not direct from Star)and it came with the Moroso Puke tank...
The guy from Star simply said to spray a little brake clean in the pump now and then to keep it clean...
I will check with the company i bought the kit from.
Thanks for the heads up!
Arnie
Re: New Star Vacuum pump installed ! [Re: cudabin] #718756
06/08/10 10:59 AM
06/08/10 10:59 AM
Out West
Out West
Arnie
Not what I was told at all. Fred hit the nail on the head. I believe their big selling point is the complete "system". The Moroso tank won't do the same thing as the Star seperator.
Post deleted by Defbob [Re: cudabin] #718757
06/08/10 11:04 AM
06/08/10 11:04 AM
Re: New Star Vacuum pump installed ! #718758
06/08/10 12:39 PM
06/08/10 12:39 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Moroso pumps are designed to have a little oil go through them for lubrication....A Star is NOT. The seperator is VERY important, don't run it without it.
Monte
Re: New Star Vacuum pump installed ! [Re: Monte_Smith] #718759
06/08/10 02:03 PM
06/08/10 02:03 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
From what i heard the star needs that canister. Buying everything for a star pump was just out of my price range so i went with a GZ pump which from what they say is made to allow some of the oil go through.
Re: New Star Vacuum pump installed ! [Re: Diablo] #718760
06/09/10 10:25 AM
06/09/10 10:25 AM
cudabin Offline OP
cudabin  Offline OP
I am running an Aluminum block 540ci on Alcohol using a Terminator mechanical injection system.
James Monroe from Killer Ron's does not recommend using the seperator w/ Mechanical Alcohol injection as the larger amount of water/oil discharge (compared to a Gas motor) quickly plugs the separator resulting in inconsistent vacuum levels. This recommendation only applies to Ron's injection apllications.
He has been using and selling Star pumps this way since 2004 with no problems what so ever...
I appreciate everyones help and advice, but in this case I am going to run it like James recommends without the separator. James gives great customer service and will stand behind what he sells.
I will let you all know how it goes.
Cheers,
Arnie
Post deleted by Defbob [Re: cudabin] #718761
06/09/10 10:44 AM
06/09/10 10:44 AM
Re: New Star Vacuum pump installed ! #718762
06/09/10 03:52 PM
06/09/10 03:52 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Fred, you don't have much confidence in those Star Vacuum Pumps do you?
I ordered mine directly from Star and they did not ever mention the separator or the 1 year warantee. Somehow I think my Pump will last a year on this car. So I think it will be a PUSH.
I do not plan on running their separator and I think I will be ok with the setup I will have.
Good luck, Ron.
SRT DEMON ONE SEAT
Re: New Star Vacuum pump installed ! [Re: Ron Silva] #718763
06/09/10 08:47 PM
06/09/10 08:47 PM
Ohio
3404 Offline
3404  Offline
Ohio
Good luck, Ron.
Same here, I bought all of my parts directly from Star and they never once mentioned the canister to me either. I dont plan on buying one at this time. No problems with mine as it is.
Re: New Star Vacuum pump installed ! [Re: 3404] #718764
06/09/10 09:38 PM
06/09/10 09:38 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Is there a good baffle system in the valve cover? I ran a similar setup, and that very same POS Moroso puke tank was horrible. it did very little to seperate the blow by and oil.
be perpaired to do a bunch of cleaning in between rounds with some brake clean and a bunch of rags.
It puked oil every pass, and blowed oil and milky stuff all over the place.
Thing was the POS tank would only have a 3-4 oz in it but would still blow crap every were...
Switched to a Steff;s tank and it was night and day diff...
Good luck.
Re: New Star Vacuum pump installed ! [Re: Bob_Coomer] #718765
06/09/10 10:15 PM
06/09/10 10:15 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Good luck.
Ditto on the moroso tank. 2 oz of oil per run and I think most of it was on the radiator core support where the tank was. I got a better tank from Mike @ Muscle Motor's, night and day the difference.
Re: New Star Vacuum pump installed ! [Re: Bigcube] #718766
06/09/10 11:20 PM
06/09/10 11:20 PM
oregon
greendart408 Offline
oregon
I also ordered mine direct from star... Very happy with the customer service . They told me at the time of purchase that in order to have the warranty that I HAD to purchase the tank also. I did and am very happy with the purchase.
Post deleted by Defbob [Re: Ron Silva] #718767
06/10/10 12:10 AM
06/10/10 12:10 AM
