New Star Vacuum pump installed !
#718748
06/08/10 12:06 AM
06/08/10 12:06 AM
Posts: 903 Saskatchewan, Canada
cudabin
Just finished installing my new Star vacuum pump. Had to move the fuel pump and get some unique sized belts, but it looks good to me, and I am now ready to start the motor tommorow night and hear what 900 ponies sound like. How does this install look??? Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Post deleted by Defbob
[Re: cudabin]
#718750
06/08/10 01:34 AM
06/08/10 01:34 AM
[Re: smokinwoody]
#718752
06/08/10 01:56 AM
06/08/10 01:56 AM
Re: New Star Vacuum pump installed !
#718754
06/08/10 07:47 AM
06/08/10 07:47 AM
Posts: 3,456 Out West
408strokerdart
Out West
Did you buy it used ? It is missing a very critical part the seperator tank. I have the mountain motor version. this is the first installation that I have seen that does not use their tank.I felt one of if not the main advantage of the Star units was in it being non lubricated and also using that tank . Why would you want to pull thru the pump when Star puts an emphasis on keeping the pump dry and oil free? The way it's now routed oil and dirt will wind up inside it for sure and do it harm. When then tank is used everything in drawn thru the tank's filters before getting to the pump itself.This will keep pump life at a very high level .Other designs need much more attention and frequent rebuilds due to dirt going thru their vanes. Star will not warranty the pump unless the tank is used. You should seriously consider getting one before you hurt the pump.
Mine has the seperator and I have never seen a Star installed without it.
[Re: 408strokerdart]
#718755
06/08/10 10:00 AM
06/08/10 10:00 AM
cudabin
I bought it new as a kit, (not direct from Star)and it came with the Moroso Puke tank...
The guy from Star simply said to spray a little brake clean in the pump now and then to keep it clean...
I will check with the company i bought the kit from.
Thanks for the heads up!
Arnie
[Re: cudabin]
#718756
06/08/10 10:59 AM
06/08/10 10:59 AM
408strokerdart
Out West
Arnie
Not what I was told at all. Fred hit the nail on the head. I believe their big selling point is the complete "system". The Moroso tank won't do the same thing as the Star seperator.
[Re: cudabin]
#718757
06/08/10 11:04 AM
06/08/10 11:04 AM
[Re: Diablo]
#718760
06/09/10 10:25 AM
06/09/10 10:25 AM
cudabin
I am running an Aluminum block 540ci on Alcohol using a Terminator mechanical injection system. James Monroe from Killer Ron's does not recommend using the seperator w/ Mechanical Alcohol injection as the larger amount of water/oil discharge (compared to a Gas motor) quickly plugs the separator resulting in inconsistent vacuum levels. This recommendation only applies to Ron's injection apllications. He has been using and selling Star pumps this way since 2004 with no problems what so ever... I appreciate everyones help and advice, but in this case I am going to run it like James recommends without the separator. James gives great customer service and will stand behind what he sells. I will let you all know how it goes. Cheers, Arnie
[Re: cudabin]
#718761
06/09/10 10:44 AM
06/09/10 10:44 AM
#718762
06/09/10 03:52 PM
06/09/10 03:52 PM
Posts: 1,880 USA
Ron Silva
USA
Fred, you don't have much confidence in those Star Vacuum Pumps do you?
I ordered mine directly from Star and they did not ever mention the separator or the 1 year warantee. Somehow I think my Pump will last a year on this car. So I think it will be a PUSH.
I do not plan on running their separator and I think I will be ok with the setup I will have.
Good luck, Ron.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#718763
06/09/10 08:47 PM
06/09/10 08:47 PM
Posts: 1,369 Ohio
3404
Ohio
Good luck, Ron.
Same here, I bought all of my parts directly from Star and they never once mentioned the canister to me either. I dont plan on buying one at this time. No problems with mine as it is.
[Re: 3404]
#718764
06/09/10 09:38 PM
06/09/10 09:38 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Is there a good baffle system in the valve cover? I ran a similar setup, and that very same POS Moroso puke tank was horrible. it did very little to seperate the blow by and oil. be perpaired to do a bunch of cleaning in between rounds with some brake clean and a bunch of rags. It puked oil every pass, and blowed oil and milky stuff all over the place. Thing was the POS tank would only have a 3-4 oz in it but would still blow crap every were... Switched to a Steff;s tank and it was night and day diff... Good luck.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Ron Silva]
#718767
06/10/10 12:10 AM
06/10/10 12:10 AM
[Re: Bob_Coomer]
#718768
06/10/10 01:09 AM
06/10/10 01:09 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Good luck.
I fixed that with an inline reservoir tank.. Problem solved..
Chris..
#718769
06/10/10 12:01 PM
06/10/10 12:01 PM
Posts: 241 Princeton, MN
racingduster
Princeton, MN
HEMIFRED, Do you have any more pics on how you mounted your stuff to your engine plate? lookes like we are using most of the same stuff. I like how you did yours. Its clean.
Thank you
Americans will put up with anything provided it doesn't block traffic.
- Dan Rather
