09 Town & Country Touring rear brake service #718698
06/07/10 11:29 PM
06/07/10 11:29 PM
central PA
mopartial Offline OP
central PA
Rear disc has parking brake tied into caliper. How do you compress caliper piston? Usual method doesnt work...
Oh and I really enjoyed caliper bolts: bigger than 11/16, smaller than 3/4, and not metric either. 23/32? 17.5mm? Thanks DC!
If it aint broke, dont break it.
Re: 09 Town & Country Touring rear brake service [Re: mopartial] #718699
06/08/10 08:26 AM
06/08/10 08:26 AM
Ohio
Todd Offline
Todd  Offline
Ohio
The pistons need rotated clockwise while pushing in. The bolt head on the caliper mount is 18mm. Just did one this morning.
Re: 09 Town & Country Touring rear brake service [Re: Todd] #718700
06/08/10 08:57 AM
06/08/10 08:57 AM
central PA
central PA
Thanks for reply.
Bolt head is swimming in 18mm box wrench or 6 point socket(?) Doesnt seem right to me.
Rotating piston while pushing? will be a chore to get caliper off disc since there is a ridge...
Geez, disc brakes were always so easy...
Re: 09 Town & Country Touring rear brake service [Re: mopartial] #718701
06/08/10 09:36 AM
06/08/10 09:36 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I used a 6 point 18mm socket. Maybe your wrench is worn. Take the caliper off the caliper mount first then remove the mount then the rotor. Will need a special tool to push the caliper piston back in. Should be avalible at for loan at the local parts store.
Re: 09 Town & Country Touring rear brake service [Re: Todd] #718702
06/08/10 04:53 PM
06/08/10 04:53 PM
central PA
central PA
Picture worth a thousand words. I was afraid there was a special tool for that.
Thanks for great reply.
