which master cylinder #718617
06/07/10 10:30 PM
06/07/10 10:30 PM
SIDNEY,OHIO
P
PROSATELLITE Offline OP
P
SIDNEY,OHIO
i have a 67 b-body with manual 10 inch drum brakes.i have purchased wilwood front and rear disk brakes,which master cyl. would you recommend?can i still use the factory dist. block?thanks in advance
Re: which master cylinder [Re: PROSATELLITE] #718618
06/07/10 11:25 PM
06/07/10 11:25 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used the MP 1 1/8 bore master W/ my Wilwoods. It has a 70/30 split so I didn't bother adding another proportioning valve and it's been great for years.
Re: which master cylinder [Re: PROSATELLITE] #718619
06/08/10 06:32 PM
06/08/10 06:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would go the 1 1/8 like Bill did.... but I would
install a prop valve if your running slicks or big
rear tires.... the 70/30 was designed for production
size tires(like equal size or close)... once you put
big rears and skinny fronts you dont want the fronts
to take all that load anymore on a hard hit of the
pedal... a prop valve just slows the initial hit then
slowly the pressure equalizes
Re: which master cylinder [Re: MR_P_BODY] #718620
06/09/10 08:16 AM
06/09/10 08:16 AM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
Just go to a local parts store and get one for a 79 Ramcharger for 40 bucks....That exact same one Wilwood sells for $100
Re: which master cylinder [Re: sc301v] #718621
06/09/10 09:29 AM
06/09/10 09:29 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I used the Strange MC on my car and this is the best price I know of. Be sure and select the 1-1/8" bore size.
If you install a Porportioning VV it needs to go in the FRONT if you are running big back tires/slicks and drag fronts.
My car locks up the FRONT wheels first and I do not have a Prop VV.
http://www.quartermax.com/details.php?prodID=414&catID=90
SRT DEMON ONE SEAT
Re: which master cylinder [Re: sc301v] #718622
06/09/10 11:04 AM
06/09/10 11:04 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Can that MC be used straight up or does it need a power booster?
Chris from New Jersey
Re: which master cylinder [Re: fig426] #718623
06/09/10 12:22 PM
06/09/10 12:22 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I have the large bore MP 1 1/8th master cylinder on 4 pot wilwoods. I find the pressure needed to stop a little too much for comfort sometimes. Wilwood recommended a smaller bore for more line pressure but you have further pedal travel.
HTH's.
Re: which master cylinder [Re: Tig] #718624
06/09/10 12:51 PM
06/09/10 12:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
HTH's.
Depends on pedal ratio also... a longer arm from the
pivot makes it easier
