Trim Removal Question #717997
06/06/10 11:05 PM
06/06/10 11:05 PM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
I know this is one of many dumb questions I'll have, but what is the easiest way to get the drip rail trim off of a 65 Plymouth Belvedere 1 with out hurting the trim or the rail?
Re: Trim Removal Question [Re: KD800X] #717998
06/07/10 01:39 AM
06/07/10 01:39 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Some will use a wood stick. It sounds hillbilly but it can keep from scratching the paint and from bending the trim. Otherwise, NAPA sells a few trim removal tools.
Re: Trim Removal Question [Re: KD800X] #717999
06/07/10 03:01 AM
06/07/10 03:01 AM
beedees Offline
beedees  Offline
I've used an old-fashioned bottle- opener (tape it up first). Works great.
Re: Trim Removal Question [Re: beedees] #718000
06/07/10 03:30 AM
06/07/10 03:30 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Yeah... I almost wrote that, then had a brain fade. Life after 40.......
Re: Trim Removal Question [Re: Kern Dog] #718001
06/07/10 01:59 PM
06/07/10 01:59 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
That trim can be tricky and it's not reproduced so hurting it would suck.
I took mine off by hand starting at the front edge. Push down on the trim to take the tension off the bottom. Pull it up from the bottom and work your way back slowly. You can start it with a wood stick or special plastic trim tool if you like. After you get it started you *should* be able to pull it off with just hand pressure. Use the tool carefully if you get stuck. When I did mine I wondered if a little silicon spray would let it slide off easier.
Re: Trim Removal Question [Re: HitIt] #718002
06/07/10 06:39 PM
06/07/10 06:39 PM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
Great info guys, thanks! I'll try it tonight if I get a chance.
I don't have to worry about paint right now, my biggest fear was damaging the drip rail and the trim. I'll try to hit it with some spray to see if that helps.
Thanks again
