Slant 6 guys HELP!! iwth exhaust leak "manifold" #716913
06/05/10 05:49 PM
06/05/10 05:49 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
A couple of weeks ago I developed a leak between the inttake and exhaust manifolds, Pulled them apart and saw 1/2 of the tin gasket was missing. Went an got an new gasket and installed top side up, then bolted all back. Fired her up and leak still there!! Ok pulled her all apart again made sure top was up and this time bolted the two manifold togeather first then boleted to head, fired her up and still a leak What am I missing? where did I go wrong?
Thanks for the help.
Diego
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: Diego_Ted] #716914
06/05/10 06:44 PM
06/05/10 06:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Have you checked both gasket mating surfaces for flatness? The blown out section of the original gasket might have caused one (or both) of the mating surfaces to "erode".
You might have to get some hi-temp composite gasket material and make your own.
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: John_Kunkel] #716915
06/05/10 06:49 PM
06/05/10 06:49 PM
smyrna,tn
draginmopars Offline
smyrna,tn
I did look at the surface they looked ok, nothing out of the ordenary? The leak is under the carb, not at the head.
thx, Ted
Hummm, My reply disappeared, and got re written
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: draginmopars] #716916
06/05/10 07:55 PM
06/05/10 07:55 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
you have to make sure the two manifolds mate up properly at the gasket surface. They my actually need to be machined. The two manifolds should be bolted together a little loose then bolt the set up to the head. snug up the manifold bolts and check for any miss alignment. If it's tight torque em down then torque it all to the head.
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: bboogieart] #716917
06/05/10 09:38 PM
06/05/10 09:38 PM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
Check out Remflex gaskets. They work great between the manifolds and where they bolt to the head.
Eric
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: Erics5th] #716918
06/05/10 11:54 PM
06/05/10 11:54 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
IIRC, the Slant 6 is prone to cracking the exhaust manifold; had that problem 20-25 years ago on one.
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: draginmopars] #716919
06/06/10 12:05 AM
06/06/10 12:05 AM
ill
dennismopar73 Offline
ill
take to shop dress it up for flattness
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: dennismopar73] #716920
06/06/10 12:27 AM
06/06/10 12:27 AM
Diego-Town, CA
Diego-Town, CA
After a little research I guess this is a common problem with the crappy tin gasket. There is a company in Oz that makes a good replacment gasket, I have two on the way!!
Diego
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: topside] #716921
06/06/10 12:13 PM
06/06/10 12:13 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
And that is because people over torque them to the engine. I believe they should be torqued to 10 ft lbs at the block.
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: stubbs300 ] #716922
06/07/10 08:23 PM
06/07/10 08:23 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Not necessarily. I had one in a Fury that cracked with over 100K on it. My Dad bought the car new and the manifold had never been off.
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold" [Re: Reggie] #716923
06/07/10 08:32 PM
06/07/10 08:32 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
cracked slant 6 exhaust manifolds are apparently fairly common. Mine cracked on my 1987 Dodge truck I have owned since new. My mechanic found an aftermarket new replacement manifold.
