Slant 6 guys HELP!! iwth exhaust leak "manifold"
#716913
06/05/10 05:49 PM
06/05/10 05:49 PM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
A couple of weeks ago I developed a leak between the inttake and exhaust manifolds, Pulled them apart and saw 1/2 of the tin gasket was missing. Went an got an new gasket and installed top side up, then bolted all back. Fired her up and leak still there!! Ok pulled her all apart again made sure top was up and this time bolted the two manifold togeather first then boleted to head, fired her up and still a leak What am I missing? where did I go wrong? Thanks for the help. Diego
Re: Slant 6 guys HELP!! iwth exhaust leak "manifold"
[Re: Diego_Ted]
#716914
06/05/10 06:44 PM
06/05/10 06:44 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Have you checked both gasket mating surfaces for flatness? The blown out section of the original gasket might have caused one (or both) of the mating surfaces to "erode".
You might have to get some hi-temp composite gasket material and make your own.
[Re: John_Kunkel]
#716915
06/05/10 06:49 PM
06/05/10 06:49 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
I did look at the surface they looked ok, nothing out of the ordenary? The leak is under the carb, not at the head. thx, Ted ^^^^^^^^ Hummm, My reply disappeared, and got re written
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: bboogieart]
#716917
06/05/10 09:38 PM
06/05/10 09:38 PM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
Check out Remflex gaskets. They work great between the manifolds and where they bolt to the head.
Eric
[Re: draginmopars]
#716919
06/06/10 12:05 AM
06/06/10 12:05 AM
Posts: 2,177 ill
dennismopar73
ill
take to shop dress it up for flattness
[Re: topside]
#716921
06/06/10 12:13 PM
06/06/10 12:13 PM
Posts: 1,181 Lost in the ozone again
stubbs300
Vacation
Vacation
IIRC, the Slant 6 is prone to cracking the exhaust manifold; had that problem 20-25 years ago on one.
And that is because people over torque them to the engine. I believe they should be torqued to 10 ft lbs at the block.
[Re: stubbs300 ]
#716922
06/07/10 08:23 PM
06/07/10 08:23 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
Not necessarily. I had one in a Fury that cracked with over 100K on it. My Dad bought the car new and the manifold had never been off.
