trans problem #716747
06/05/10 01:26 PM
06/05/10 01:26 PM
West Michigan, Usa.
K
killersix Offline OP
K
West Michigan, Usa.
Trying to help figure out another persons trans problem. It is a fresh 727 put together by local trans shop.All the good stuff done as in billet drum,low gear set, rollerized output support, low band apply brake. Has a problem with fluid coming out of the relocated vent on rear of the case after car idles around the pits. Even added extension tube to bring it up 18 inches or so and it still does it. Pulled the tailshft housing to double check location of vent correct per instuctions. Any ideas?
Re: trans problem [Re: killersix] #716748
06/05/10 02:35 PM
06/05/10 02:35 PM
NC
440Jim Offline
440Jim  Offline
NC
Is this where they put the new vent?
Re: trans problem [Re: 440Jim] #716749
06/05/10 02:55 PM
06/05/10 02:55 PM
West Michigan, Usa.
K
K
West Michigan, Usa.
Yes.
Re: trans problem [Re: killersix] #716750
06/05/10 03:11 PM
06/05/10 03:11 PM
NC
440Jim Offline
440Jim  Offline
NC
I wonder if the gasket is sealing off the bottom of the passage (the rib under the drill bit). Then the cavity could fill with fluid from the top and go out the vent. When I did mine, I ground a little better drain slot in that lower rib behind the rear support, but left the rib for splash protection.
Re: trans problem [Re: 440Jim] #716751
06/05/10 03:26 PM
06/05/10 03:26 PM
West Michigan, Usa.
K
K
West Michigan, Usa.
It looked like that could happen so when i had the tail stock off I drilled a 3/16 hole in the rib under the vent thinking the same thing. Then I threaded the hole for an 1/8 tube fitting so he could run a solid tube up the back of the case to be sure it wasn't just sloshed up the vent. I cannot figure how it could be pushing fluid up that much tubing but it is. It is on a Hemi A- body with a blanket so it is a P.I.T.A. to pull.
Re: trans problem [Re: killersix] #716752
06/05/10 06:11 PM
06/05/10 06:11 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i chased this problem last season too. for the life of me i couldn't work out how so much fluid could get up in that area. the gasket almost acts as a splash shield & yet i was probably loosing an ounce or 3 every run.
i ended up making a new vent on the tailshaft & extending a hose up towards the firewall. at the end of the hose i fitted an old 3/8 fuel filter to act as an expansion chamber. this would allow the system to "burp" the air bubble out without spewing the fluid in the line in front of it. to top it off i have a mini K&N style filter fitted to the outlet side of the fuel filter so it don't look so agrigcultural.
with this mod, any fluid that comes out the vent now gravity feeds back into the trans on the drive back to the pit. sure makes it cleaner to climb under the car these days.
Re: trans problem [Re: rebel] #716753
06/05/10 06:18 PM
06/05/10 06:18 PM
NC
440Jim Offline
440Jim  Offline
NC
I wonder if transmissions with this problem (and this vent relocation) might be due to the rear support not laying flat on the case and spraying fluid from the cooler return line at the vent?
Re: trans problem [Re: rebel] #716754
06/05/10 06:18 PM
06/05/10 06:18 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
This won't help your problem, but the next trans brake I install, I'll drill the relief hole in the piston, instead of the drum. I think that's a Tranzact idea. Is it hard to fill, as if it's not venting?
Re: trans problem [Re: 440Jim] #716755
06/05/10 08:44 PM
06/05/10 08:44 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i thought it maybe related to the park lever cogg flicking fluid after launch? my thinking was the fluid getting pushed back to be deep enough in the tailshaft for the cogg to make contact & start spraying all around the tailshaft & the exhaust venting of the trans was picking up this spray & pumping out the vent. maybe yes?
Re: trans problem [Re: rebel] #716756
06/06/10 02:26 PM
06/06/10 02:26 PM
Shelby Twp Michigan
727jim Offline
super gas
727jim  Offline
super gas
Shelby Twp Michigan
are the govenor weights pulled if so have you taped and pluged the govenor feed port of not it will spray out of the vent
good luck
Re: trans problem [Re: 727jim] #716757
06/06/10 08:57 PM
06/06/10 08:57 PM
West Michigan, Usa.
K
K
West Michigan, Usa.
Yes the weights are pulled. The last groove in the housing for the park pawl sticks out of the roller support and doesn't have a seal ring on it. Would a rev/manual/brake valve body even pressurize that circuit? I guess I will call the support manufacturer and see what info they have. Also did put a clear filter pointing up on to stop the flow for now. Thanks for the input so far. will look into the govenor issue next. JB.
