Page 3 of 7 1 2 3 4 5 6 7
Re: 1972 Dart street toy. [Re: demon1515] #716349
05/05/11 03:50 PM
05/05/11 03:50 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
here is the rear brake setup, ( on the really cheap )
it consist of a set of used FLEABAY Wilwood calipers in good condition, call aerospace components and they sold me just the brackets for the mopar ends, and a 2005 Nissan Maxima rear rotors, they just fit perfect.
Could you please list the part numbers of everything you used to convert the brakes over to disc.
Re: 1972 Dart street toy. [Re: moparpollack] #716350
05/05/11 07:32 PM
05/05/11 07:32 PM
ATL GA
demon1515 Offline OP
ATL GA
Well all i can tell you is the part number of the brake rotors from Autozone but you really don't need that part number cuz any rear brake rotor from a 2005 nissan Maxima will work, then the caliper bracket from Aerospace Components for a Mopar Rear end they just have that one, and the calipers are old wilwood solid rotor caliper Dinalite, thats all you need to know to get the same setup on your car,
remember my axles are custom moser ones so you may need to tweak a little the brake rotors to fit your specific axle but it will be very easy to do so with a carbide bit on your die grinder, also my axles are 2.5 offset just like factory so there should be no issues with the depth on the brake rotor and anyway the caliper bracket is adjustable there!
Re: 1972 Dart street toy. [Re: demon1515] #716351
05/06/11 10:55 PM
05/06/11 10:55 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Demon1515 check your pm
Re: 1972 Dart street toy. [Re: RV2] #716352
05/07/11 01:05 AM
05/07/11 01:05 AM
ATL GA
ATL GA
Got it buddy, and back to you.
Re: 1972 Dart street toy. [Re: demon1515] #716353
05/12/11 05:54 PM
05/12/11 05:54 PM
ATL GA
ATL GA
New QA1 shocks single adjust are here,
THANKS PARADISE RACING!
SRD ASSASSIN BARS ordered, thanks Jake.
Re: 1972 Dart street toy. [Re: demon1515] #716354
05/24/11 01:18 PM
05/24/11 01:18 PM
ATL GA
ATL GA
Re: 1972 Dart street toy. [Re: demon1515] #716355
05/25/11 11:15 AM
05/25/11 11:15 AM
ohio
70shaker6pk Offline
super gas
70shaker6pk  Offline
super gas
ohio
Looking good!!
Re: 1972 Dart street toy. [Re: 70shaker6pk] #716356
05/25/11 11:53 AM
05/25/11 11:53 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
You have made some great progress. I really like the side stance too.
65 Barracuda
70 Challenger
Re: 1972 Dart street toy. [Re: jrwoodjoe] #716357
05/31/11 01:01 AM
05/31/11 01:01 AM
ATL GA
ATL GA
A little update not so big but very significant at least to me hehehe
Firewall holes patched no mud yet i will leave that to the bodyman.
Before
After
First gen Mazda RX-7 seats
Still need to die em Black
Painted alternator but i don't think i will end up using it, i think i will change for a modern one!
clutch brake pedal assembly ready for the pedal pads and still need to deal with the hydraulic clutch conversion.
And the willwood master and adapter installed.
Re: 1972 Dart street toy. [Re: demon1515] #716358
06/01/11 06:41 PM
06/01/11 06:41 PM
ATL GA
ATL GA
More small updates here,
Front brake caliper bracket template done today, now i just need to copy it on 3/16 sheet metal and bolt it up together!
front rotor and hub assembly!
Re: 1972 Dart street toy. [Re: demon1515] #716359
06/01/11 09:09 PM
06/01/11 09:09 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Is that the stock drum hub? and what application is the rotor?
Re: 1972 Dart street toy. [Re: RV2] #716360
06/01/11 09:34 PM
06/01/11 09:34 PM
ATL GA
ATL GA
Yes that's the stock drum hub re-drilled to 4.5 bolt pattern and the rotor is a 1991 Mazda RX-7 Turbo II.
Re: 1972 Dart street toy. [Re: demon1515] #716361
06/05/11 10:49 PM
06/05/11 10:49 PM
ATL GA
ATL GA
Once again some small updates,
I do have some fun this weekend, cleaning and scrubbing the tar or fendix stuff it got from factory, tough stuff there, and still need to do all the under carriage and back tubs, but little by little,
In another note, i am going to add QA1 shocks up front too and upper tubular A arms, so this don't stop here
Re: 1972 Dart street toy. [Re: demon1515] #716362
06/08/11 09:00 PM
06/08/11 09:00 PM
ATL GA
ATL GA
My little one helping me on the front end!
Re: 1972 Dart street toy. [Re: demon1515] #716363
08/12/11 07:09 PM
08/12/11 07:09 PM
ATL GA
ATL GA
A little more done today, finally finish the mini tubing welding, inside the trunk and inside the car.
Re: 1972 Dart street toy. [Re: demon1515] #716364
08/12/11 08:24 PM
08/12/11 08:24 PM
Looks good, weld beads look good as well.
Re: 1972 Dart street toy. [Re: ] #716365
08/13/11 12:49 AM
08/13/11 12:49 AM
ATL GA
ATL GA
Thanks, i do what i can with my little Sp135 Plus welder and my small carport, plus the help of my little daughter.
Re: 1972 Dart street toy. [Re: demon1515] #716366
09/03/11 12:40 AM
09/03/11 12:40 AM
ATL GA
ATL GA
Now, i like it better with the cowl scoop!
Re: 1972 Dart street toy. [Re: demon1515] #716367
09/03/11 11:34 AM
09/03/11 11:34 AM
What does it look like turned 180*?
Re: 1972 Dart street toy. [Re: ] #716368
09/03/11 01:19 PM
09/03/11 01:19 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
You may be onto something here
