Re: 1972 Dart street toy.
[Re: demon1515]
#716349
05/05/11 03:50 PM
05/05/11 03:50 PM
moparpollack
Lil Herman
Lil Herman
85086
here is the rear brake setup, ( on the really cheap ) it consist of a set of used FLEABAY Wilwood calipers in good condition, call aerospace components and they sold me just the brackets for the mopar ends, and a 2005 Nissan Maxima rear rotors, they just fit perfect.
Could you please list the part numbers of everything you used to convert the brakes over to disc.
[Re: RV2]
#716352
05/07/11 01:05 AM
05/07/11 01:05 AM
Posts: 234 ATL GA
demon1515
ATL GA
Demon1515 check your pm
Got it buddy, and back to you.
[Re: demon1515]
#716353
05/12/11 05:54 PM
05/12/11 05:54 PM
Posts: 234 ATL GA
demon1515
ATL GA
New QA1 shocks single adjust are here, THANKS PARADISE RACING! SRD ASSASSIN BARS ordered, thanks Jake.
[Re: jrwoodjoe]
#716357
05/31/11 01:01 AM
05/31/11 01:01 AM
Posts: 234 ATL GA
demon1515
ATL GA
A little update not so big but very significant at least to me hehehe Firewall holes patched no mud yet i will leave that to the bodyman. Before After First gen Mazda RX-7 seats Still need to die em Black Painted alternator but i don't think i will end up using it, i think i will change for a modern one! clutch brake pedal assembly ready for the pedal pads and still need to deal with the hydraulic clutch conversion. And the willwood master and adapter installed.
[Re: RV2]
#716360
06/01/11 09:34 PM
06/01/11 09:34 PM
Posts: 234 ATL GA
demon1515
ATL GA
Is that the stock drum hub? and what application is the rotor?
Yes that's the stock drum hub re-drilled to 4.5 bolt pattern and the rotor is a 1991 Mazda RX-7 Turbo II.
[Re: demon1515]
#716364
08/12/11 08:24 PM
08/12/11 08:24 PM
Looks good, weld beads look good as well.
[Re: demon1515]
#716367
09/03/11 11:34 AM
09/03/11 11:34 AM
What does it look like turned 180*?
[Re: ]
#716368
09/03/11 01:19 PM
09/03/11 01:19 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
You may be onto something here
