Where should I be setting the timing on my basically stock 1970 383 (335HP) motor?
Car has the original solenoid type distributor but I don't have the original carb with the solenoid contact, therefore the solenoid is not functioning.
My understanding of the distributor solenoid is that it is designed to retard the timing at idle for better emissions. Therefore, when the car is started, timing is advanced to about 10 degrees and then once is starts the timing is retarded to TDC.
The Tune up spec for setting the timing is TDC for a manual trans.
Without the original carb should I just be setting initial timing to about 12 BTC as is specified for not CAP cars?
Also, to what degree does the timing need to be adjusted for today's modern day fuel blends?
![](/ubbthreads/images/graemlins/shruggy.gif)
