Dyno Results for my Stroker Six Pack #715593
06/03/10 11:06 PM
06/03/10 11:06 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Hi Guys,
Just thought I'd post the dyno results of my 496-6 that Nick Wilson at Compuflow built for me. Right now all I can do is give the numbers as I won't get the dyno sheets or the build sheet from Nick until next week but he told me the motor made 735 hp max at 6900 rpm and torque was 633 lb-ft at 4000. I should note that they didn't start the dyno runs until 4000 rpm and the torque was decreasing at that point so the max torque was probably higher than the 633 but how much more we don't know.
I asked Nick to make 1 pull with my factory air cleaner in place (using a K & N element) and peak hp was only down 4 hp at 731 max.
The basics on my motor are:
-70 440 block w/Eagle crank and rods
-Indy aluminum SR heads ported by Nick
-11.5 CR
-Comp Cams roller cam
-Aluminum 6 pack manifold with a stage II
porting by Hughes
-Harland Sharp roller rockers
-my carbs were prepped by Dale Cubic at CFM
Carburetors and Dale was on hand at the dyno to do the tuning.
When I get the build and dyno sheets next week I can post some more information.
Thanks Nick and Dale!
383man [Re: 70BIRD] #715594
06/03/10 11:10 PM
06/03/10 11:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That sounds like it is making good HP for the combo. What car is it going in ? A 70 Runner is my guess. Ron
Re: 383man [Re: 383man] #715595
06/03/10 11:14 PM
06/03/10 11:14 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Sounds like it's making some steam.
Re: 383man [Re: 383man] #715596
06/03/10 11:20 PM
06/03/10 11:20 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
You are correct, it's going in a 70 Road Runner with a 4 speed and a 4:10 Dana.
Re: 383man [Re: 70BIRD] #715597
06/03/10 11:31 PM
06/03/10 11:31 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
A very clean RR at that
Nice #'s
You got it in the car yet.
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715598
06/03/10 11:33 PM
06/03/10 11:33 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
i worked with Dale a few times when I did engine masters with livernois. he's a great guy to work with.
Very stout power by the way!!!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: 383man [Re: WILD BILL] #715599
06/03/10 11:36 PM
06/03/10 11:36 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Thanks Bill!! It's not in yet but wiil be by Sunday!
Re: 383man [Re: 70BIRD] #715600
06/03/10 11:38 PM
06/03/10 11:38 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Just let me know what time would be good to swing by and drop off your bearing.
Re: Dyno Results for my Stroker Six Pack [Re: 68 HEMI GTS] #715601
06/03/10 11:38 PM
06/03/10 11:38 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Very nice numbers...
Even if the car is all stock and heavy, get it to hook, and that thing will go easy 9's.
Re: Dyno Results for my Stroker Six Pack [Re: Bob_Coomer] #715602
06/03/10 11:42 PM
06/03/10 11:42 PM
what specs can you share on the camshaft?
Re: Dyno Results for my Stroker Six Pack #715603
06/03/10 11:54 PM
06/03/10 11:54 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
I new somebody was gonna ask and right now I can't say because I really don't know yet what Nick ended up going with. I know he was concerned with the manifold holding things back and he actually had gotten 2 different cams ground, 1 more mild (relatively speaking) and 1 more wild so I would rather find out for sure before I say...
Re: 383man [Re: WILD BILL] #715604
06/03/10 11:59 PM
06/03/10 11:59 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Bill, I was hoping to get it on Saturday, can I give u a call tomorrow, I'm hitting the sack now been a long day!
Re: 383man [Re: 70BIRD] #715605
06/04/10 12:01 AM
06/04/10 12:01 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715606
06/04/10 05:56 AM
06/04/10 05:56 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
On a side note, You are running an unfilled production block?? What were the sonic numbers?
MB
Re: Dyno Results for my Stroker Six Pack [Re: HPMike] #715607
06/04/10 10:31 AM
06/04/10 10:31 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Dyno session with Nick and Dale present, You left no stone unturned in your search for HP
Great numbers, have fun driving sideways
Re: Dyno Results for my Stroker Six Pack [Re: HPMike] #715608
06/04/10 10:57 AM
06/04/10 10:57 AM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Mike - my block has a Hughes main stud girdle and Nick added a small amount of hard block (about 1") and the head bolts were replaced with studs as well.
As far as the sonic numbers that's way beyond my knowledge I'd have to ask Nick but I remember when Gellner first did this motor back in the 90's as a 440 build the block was sonic checked and they told me it was good block to use.
Also I mistyped the displacement, its 493 cubes: its bored .030 over and has a 4.150 stroke.
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715609
06/04/10 12:33 PM
06/04/10 12:33 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Those really are very good numbers using a 2 plane 6 pack manifold.
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715610
06/04/10 12:42 PM
06/04/10 12:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
Hi Guys,
-11.5 CR
porting by Hughes
Come on now, everybody knows them stock type six paks don't work Good results Maybe some of the naysayer on here will open thier ears and learn something from your post BTW, any idea of what compression ratio it ended up with? Is it a pump gas or race gas motor in other words?
Re: Dyno Results for my Stroker Six Pack [Re: Cab_Burge] #715611
06/04/10 12:57 PM
06/04/10 12:57 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Thanks Cab! Everyone was surprised by the rpm's and the overall numbers. Nick told me before they started the dyno testing that they thought this thing would max out at around 6200 rpm and when they made the first few pulls they stopped at 6300 but the hp was still climbing so Dale said lets run this thing all they way and see where it peaks. I have the dyno sheets now and if I can figure out how to post I will get them up but on the last run with the air cleaner assembly on the motor it peaked at 731.0 hp at 6900 rpm and at 7000 it dropped to 729.5 hp!
As far as CR it is 11.5 to 1 and I plan on mixing in a little race fuel which is what I did with my previous 440 which was at 11.7 to 1 and it seemed to run fine that way.
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715612
06/04/10 01:25 PM
06/04/10 01:25 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Let's see if I can post these sheets...
6020509-DynoResults (368 downloads)
