So if I want to make sure I'm not running out of fuel with my stockish mechanical pump, I'm thinking I can install a fuel pressure gauge and make sure I've got 4 to 5 psi left after a high speed run down a lonely road. So I don't need to run a gauge permanetly and most of the gauges I've seen install under the hood. So what do you guys do to make a quick check? Do you run an analog gauge on a long extension hose inside the car? Are there cheap electric gauge/sending units made for this purpose?
None of my kids offered to curl up under the hood with a flashlight
