Axle Studs......where to get them #714122
06/02/10 02:10 PM
06/02/10 02:10 PM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
I need some odd axle studs. There was a company that dealt in axle studs and I can not remember the name to save my self.
Any info would be appreciated
Re: Axle Studs......where to get them [Re: 62BT409] #714123
06/02/10 02:15 PM
06/02/10 02:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Dorman? Any auto parts store can order them. Or call Mark Williams Ent, they can get you anything.
Re: Axle Studs......where to get them [Re: Challenger 1] #714124
06/02/10 02:26 PM
06/02/10 02:26 PM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
YEAP...that's it Dorman. Thank you
Re: Axle Studs......where to get them [Re: 62BT409] #714125
06/02/10 04:03 PM
06/02/10 04:03 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Um Doctor Diff
Re: Axle Studs......where to get them [Re: 76dodgeboy] #714126
06/02/10 07:18 PM
06/02/10 07:18 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
As stated Motormite/Dorman whould have you covered and decent auto parts store should carry their line and/or be able to get them for ya. Good luck
Re: Axle Studs......where to get them [Re: Alikazam] #714127
06/02/10 07:22 PM
06/02/10 07:22 PM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
UPDATE: no one has nothing yet....called them all.
Re: Axle Studs......where to get them [Re: 62BT409] #714128
06/02/10 08:12 PM
06/02/10 08:12 PM
try manciniracing.com
Re: Axle Studs......where to get them [Re: 62BT409] #714129
06/02/10 09:13 PM
06/02/10 09:13 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Doctordiff couldn't help you!!! I really find that hard to believe
Gus
64 Plymouth Savoy
Dana 60
Re: Axle Studs......where to get them [Re: fourgearsavoy] #714130
06/02/10 09:33 PM
06/02/10 09:33 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
What's odd about them, clue us in?
My
Own
Personal
Adrenaline
Rush
Re: Axle Studs......where to get them [Re: 62BT409] #714131
06/02/10 10:05 PM
06/02/10 10:05 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
tell me what your working on and I see if anything exists.
just an FYI Dorman dis-continued all left hand studs a few years back and have become quite scarse to say the least
Re: Axle Studs......where to get them [Re: gtx6970] #714132
06/02/10 10:13 PM
06/02/10 10:13 PM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
All is OK now....all that was need was a good machinist. Things will be fine. Night All
Re: Axle Studs......where to get them [Re: 62BT409] #714133
06/02/10 10:16 PM
06/02/10 10:16 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I've had trouble getting the low grade studs to pull into the axles. ARP studs zip right in. The others just stripped off the threads. Distorted the washers I was using.
I want my fair share
Re: Axle Studs......where to get them [Re: SomeCarGuy] #714134
06/03/10 06:49 AM
06/03/10 06:49 AM
Cincinnati, Ohio
Cincinnati, Ohio
Your supposed to use a press to install them.
Re: Axle Studs......where to get them [Re: Challenger 1] #714135
06/03/10 07:21 AM
06/03/10 07:21 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Yah but sometimes you NEED to replace a stud. I used to keep a complete set with some head stud washers (thick!) and an open end nut that was flat on one side to replace studs at the track if for some reason one galled or anything. Nothing like a quick stud replacement when swapping out the slicks!!!
