440 BLOCK #714107
06/02/10 01:55 PM
06/02/10 01:55 PM
SD800 Offline OP
SD800  Offline OP
I found a number stamped into the bottom of the block on the pan rail surface or the ear the starter bolts to. The number is PT440S22011763, kinda thought it was a weird number and location, anyone know what the number means. the block was cast 4-67
You'll have plenty of time to sleep when your dead, let's go
Re: 440 BLOCK [Re: SD800] #714108
06/02/10 03:22 PM
06/02/10 03:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That is the engine serial number, not found on all blocks.
PT440S22011763
PT= Plant Trenton, built at the Trenton engine plant
440= Displacement
S= Special Engine (Warranty Replacement)
2201= Build date August 7, 1967
1763= Sequence number, the 1763rd built that day.
Re: 440 BLOCK [Re: John_Kunkel] #714109
06/02/10 05:16 PM
06/02/10 05:16 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Guys on Moparts are way better at decoding than Galen could ever hope for.
Of course it takes 10,000 of us, but....
This is the best da.mn freebie source!!!
